converting 6 volt to 12 votl in 40 desoto? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2004, 11:23 PM
whats all in volved in converting 6 volt to 12 volt?
Old 05-25-2004, 05:31 AM
Wiki Edits: 49
I'm no electrical expert but have gleaned this from a friend who is.
You can change all your bulbs to 12 volt. Nothing else needed there. You will need to add a coil resistor to the coil for it to operate properly. The starter will operate OK on 12 volts. You’ll have to use 2 step down resistors in parallel for the heater and for the instruments you’ll want to use a Radio Shack heavy duty DC Auto voltage adapter. part number 2731815. Set the slide switch to 6 volts, cut the wires off and wire the input to your ignition switch and the output to your instruments. Add 1 step down resistor for the radio and you should be all set.
Centerline
Old 05-25-2004, 06:03 AM
BOBCRMAN@aol.com's Avatar
CENTERLINE is correct. And thanks for that part no. I usually get a Volt-a-Drop unit from good old J C Whitney to do the job. The wiring in a six volt system is heavier than a twelve volt system and (if in good shape) works well. I usually just install a 12 volt battery, ground the negative side, then replace all the bulbs that blow out. Volt-a-Drop covers the instruments and motors. A chrysler ign resister for the coil. Then use a one wire GM. alternator to charge the system.
Old 05-25-2004, 08:06 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
here's 2 site w/some good info on it....joe
http://clubs.hemmings.com/clubsites/...o_12_volts.htm
http://www.imperialclub.com/Repair/E...al/convert.htm
Old 06-03-2004, 10:58 PM
thanks alot for all the info...this is very helpful and just what i was looking for...
