Converting an '83 Scottsdale 2Wheel Drive to 4x4
ok, so here's a project that I'm considering at the moment.
I have a screamin deal on an 83 scottsdale 2 wheel drive truck, that is like in near mint shape. If I were to buy this truck the thing I want is 4x4. I have an entire other running, driving 84 4x4 truck with a weak frame under it. So I guess my question is how hard is it to swap the 4x4 out and install into the new truck? I always thought that all the frames were generic, with all holes in all frames, and it would be all bolt in stuff. Is there anything I'm missing? If this job is just too much, I might have second thoughts on buying it in the first place. I cant find any good 4x4 in my area except for a few that ppl want waaayyyy more than they are worth. I practically have all parts needed already to do this I think. What do you guys think?? Also, is there any other liks dealing with this specific issue? or, any online articles on this? Any and all help is appreciated!!!! |
Check your frames out closely, I don't think they are the same.
Ontario Rodders |
These guys will definitely be able to tell you what you need to do. Its a slower moving board, but you'd be hard pressed to find group anywhere else that know more about these trucks.
http://www.73-87chevytrucks.com/ There's a light truck wreckers near me that said I could convert my '87 1/2 ton to a 1 ton Dually if I wanted. Maybe the frames are the same with different spring perches and transmission cross beams. All the spring perches on these are hot riveted, I'd think you can drill them out & use Grade 8 bolts. Gear |
He is asking the difference between a 2 wheel drive and 4 wheel drive frame............not 1/2 ton and 1 ton........But, its good to know.
Ontario Rodders |
i figured thats what he was asking, i didnt know, but i thought id add the tid bit of knowledge i did know, i'll get ahold of my 4x4 buddy this afternoon and ask him if he knows the difference between 2 and 4 wheel drives.
BTW have you tried googling the subject? |
Having a 79 Chev C-10
Used to have a 78 K-10 They are different--spring perches, suspension hangars, engine mounts, and some subtle frame horn dimensions from the cab forward. Also-----the floor of a 2 wheel drive truck is very different than a 4x4. This difference is not only in the trans tunnel----but under the seat as well. You would be much better off locating a 4x4 chassis that is in good shape and go from there----then your only modification would be the cab floor, which--if you already have a thrashed 4x4 cab--could provide the floor piece. Bryan |
glad I asked, I think I might do more searching on this, then, probably sell it all and buy a horse and buggy
anyone know if its possible to do it on a F250?
Dunno----My 05 Ranger is my first Ford truck----well, it wishes it were a truck
Bryan |
| 2 Wheel drive to 4X4 conversion | Sonny's 75 | Hotrodding Basics | 21 | 06-20-2009 09:17 AM |
| 83' s-10 700r4 4x4 trans took a dump | proflow | Transmission - Rearend | 2 | 12-12-2006 12:51 AM |
| Jamie's 83' chevy 4x4 | jamie dengler | Introduce Yourself | 1 | 04-08-2006 10:46 AM |
| headers for a 83 chevy 4x4 with sbc brodix angle plug heads | jrtraveler79 | Engine | 1 | 04-23-2004 11:04 PM |
| Converting 2wd 700r4 to 4x4 | dboriack | Transmission - Rearend | 2 | 02-12-2004 06:09 AM |
