We're winning the case!
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 02-04-2006, 09:53 PM
CarMazed CarMazed is offline
converting 9" ford rearend with 4.75 b.c. to disc brakes
I am wanting to convert a 9" rearend with redrilled to chevy 4.75 b.c. axles to a disc brake rear without buying the high buck aftermarket conversion, does anyone have any suggestions for this using parts store available rotors and calipers to where I can use or build mounting bracket. I would also like to have e-brake as part of the setup. all suggestions appreciated. Thanks CarMazed
Old 02-04-2006, 11:40 PM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
powerrodsmike's barnstar
Wiki editor
Last wiki edit: 9 things you need to know about the Crankshaft Coalition Wiki
Wiki Edits: 161
Welcome to HRBB. this is a good place.
take the rotors to a machine shop and have them drilled to your 4.75' pattern. Here is a site that someone posted here recently that has some inexpensive brackets
http://www.scarebird.com/6928.html
Look around here on the site, search the posts and the knowledge base. there is alot of info here re rear disc setups.hope this helps, mikey
BE different....ACT normal.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "converting 9" ford rearend with 4.75 b.c. to disc brakes"
Disc Brakes for 9" Onestreetrodder Transmission - Rearend 9 01-22-2006 03:50 PM
60's Chevy rearend that looks like a ford 9", please help ID Guitar Charlie Transmission - Rearend 5 03-14-2005 09:36 AM
9" Ford Rearend rebuild blacklotus Transmission - Rearend 1 02-04-2005 04:49 PM
9" ford rearend toolmansson Transmission - Rearend 4 02-05-2002 03:14 PM
9" ford rearend 37 ford melbishop Transmission - Rearend 3 12-09-2001 09:15 AM
