Converting bead roller to power - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 11-30-2013, 08:51 AM
Wiki Edits: 27
winch
Superwinch 12 Volt Utility Winch — 2000-Lb. Capacity, Model# 1220210 | 1,000 - 2,900 Lb. Capacity Winches| Northern Tool + Equipment
northern tool has a winch that looks like the one I got from HF that has the yellow controller. The yellow controller is like the one Jim Stabe made and I copied to make a foot pedal. 'With the 12 V one you need a battery or the booster pack to run it.
the HF ad doesn't show which type of controll it has.
http://www.harborfreight.com/2000-lb...tm_source=1040
their video says 12 fr control cable. I bought the cheapest ATV winch last year for $ 50 to use on my dune buggy and It came with a key fob control, it would be hard to make a foot control for it. HF also has the 110 V winch on sale for $ 150. but I got a 25 % off cupon . so the price discount would mean in the shop I wouldn't need to buy a battery or battery pack
  #47 (permalink)
Old 01-01-2014, 06:49 PM
Wiki Edits: 27
bead roller quick release
I've got some better picts of my quick release. I welded 2 pieces of angle iron up right with a gap for 3/8 bolts, shown in the second pict. in the first pict I welded a piece of bar stock and threaded the hole for the crank , on the bottom of the all thread I welded 2 nuts to move the link up or down,
Name:	bead roller 003.jpg
ID:	110098   Click image for larger version
Name:	bead roller 005.jpg
The Following User Says Thank You to timothale For This Useful Post:
John long (01-01-2014)
  #48 (permalink)
Old 01-09-2014, 08:32 PM
powered bead roller ideas
I used a gear reduction starter from an '02 chevy malibu, gutted it and shortened the housing some. then had the armature turned down on the end so it would be 1/2" to fit my drill. then drilled out the end cap of the starter so that turned down shaft stuck through the end of the starter. i used that to power a 350 chevy flywheel that was fitted to the bead roller shaft using a weld on sprocket hub from princess auto (canadians version of harbour freight). the flywheel fits where the old hand crank used to go. then fabbed up a mount for the drill and a lever arrangement to push the drill trigger with a gas pedal style foot treadle that is rigged up with some bicycle brake cable parts to pull the drill trigger lever. it all works pretty well. i will see if I can get the pics to load. if not I will see if I can figure out how to start my own thread and attach some pics from there.
Name:	bead roller and stretcher 005.jpg
ID:	112058   Click image for larger version
Name:	bead roller and stretcher 006.jpg
ID:	112066   Click image for larger version
Name:	bead roller and stretcher 007.jpg
  #49 (permalink)
Old 01-09-2014, 08:45 PM
pics explained
ok, the pics came through, now just so you can figure it out, the bead roller was an el cheapo deluxe unit bought at kms tools in calgary. probably the same as your harbour freight units. made in china but not great for anything but thin sheet because it flexxed too much. i needed to roll some 16 ga floor sheet so i re-inforced it with 1/2" steel. then added some pipe nipples to store the extra dies and shims. then tried it but found it hard to roll anything while cranking the hand lever. i had some extra struff laying around the shop so I fabbed up the rest. one pic shows the treadle hanging on the storage pipe nipple, just to keep it off the floor. the treadle is just some extra 16 ga with a cheap hinge on one end and a spring from the junk bin to return the treadle to stopped position., all in all it was a day or so to fix it all but some of that was think time to put together what I had sitting around and make it work. I did have to get the starter shaft turned down but that was $20 cash deal at a local machine shop. bought pizza for the guys prolly, ha ha. anyway, hope it helps somebody for ideas.
dennis
  #50 (permalink)
Old 01-09-2014, 08:58 PM
hey, you guys ever seen the you tube stuff by lazze metal works? pretty good ideas and help for fab idiots like me. there is a couple others by meatalman sweden, check-em out when you have a minute or three.
  #51 (permalink)
Old 01-09-2014, 11:08 PM
Wiki Edits: 27
tip # 6
My wife asked me what I was doing trying to sneak her clothes iron out of the laundry room.
https://www.youtube.com/watch?v=K8_FP6A_mvg
  #52 (permalink)
Old 03-04-2014, 05:37 AM
deadbodyman's Avatar
Wiki Edits: 11
Any of you guys build a fence or the roller?
  #53 (permalink)
Old 03-04-2014, 06:59 AM
Wiki Edits: 27
Fence
I have a fence for mine, shown in # 13, Not a good pict , it is reversible one direction the fence is close to the rollers, and switched the opposite direction for more depth. lazze has a fence somewhere in his Youtubes, he also uses a roller fence for making curves. another handy item is a removable plywood support table for doing larger panels by yourself.
a good view of lazze's fence starting at .50
and his 3 rd axis
  #54 (permalink)
Old 03-04-2014, 04:38 PM
Wiki Edits: 11
That third axis is pretty cool...
  #55 (permalink)
Old 03-04-2014, 05:30 PM
Banned
don't people sell old junk bikes near you that you could buy for 10 bucks and have 18 speeds for your roller.. or pick what sprocket to put it on as needed (like a drill press) seems the sprockets would be cheaper that way.. and multi speed for 10 bucks
  #56 (permalink)
Old 03-15-2014, 07:02 PM
Old Fool's Avatar
I have a servo on my Adler sewing machine and know exactly what you are saying.
I have had and used my bead roller for 25 years and it is true that control is needed but having 2 hands free to guide the metal will be the big benefit. I hope and believe a constant speed will be manageable as long as it is geared slow enough. I think I will mount the motor in a way that it will be easy to remove the chain and attach a hand wheel which in itself would be a big improvement over a crank. That would be an option for any intricate patterns that had to be done.
Thanks for your thoughts.
"[quoto]Tech69 "I'd love to see your ideas. I just got a bead roller and plan to motorize it too."
Henry, you demonstrated pulling a pushed in fender with a metal plate the other day which is going to work perfectly for me where my car was "tagged" in the rear end. I jave learned sooo much here. Hopefully what I doing this will help you and some others. That is what this forum is all about and why I enjoy hanging around here so much.
John
John
A old steering wheel works great to replace the crank handle.
  #57 (permalink)
Old 04-08-2014, 04:34 PM
Wiki Edits: 11
Hey Tim, I just happened to notice that your shafts are mounted on the opposite as mine ,is there a reason for that? left handed?
  #58 (permalink)
Old 04-08-2014, 08:54 PM
Wiki Edits: 27
lefty
My son who has put the most miles on it is left handed. It was really an opps. I had it all apart when adding the motor drive systen and reinforcements, The frame is slotted so both the upper and lower shafts blocks are adjustable
  #59 (permalink)
Old 06-14-2014, 04:38 AM
Wiki Edits: 11
I got my roller skate wheel and giant washer together to make a tipping wheel but I dont see how I can mount the wheel on the roller the wheel has bearings and is mounted on a 1/4" shaft so how do you get it on the bead roller shaft? also if the skate wheel and the tipping wheel are not the same size they'll turn at different speeds so the skate wheel should be free wheeling? with bearings? how about some pics and explainations..on the tipping wheel.
  #60 (permalink)
Old 06-14-2014, 07:01 AM
Wiki Edits: 27
skateboard wheel
I stopped at a skateboard shop in town and didn't find any wheels I liked. I ordered 2 wheels from reid supply. I don't know which is which . Reids part no 1 US-105 and part no 1AU-824.
The orange one is the one I use. It is a tight push on to the harbor freight 22 mm shaft .My skate wheel turns with the shaft, not free wheeling. I was looking at drilling a washer and bolting it in place of the harbor freight cutting die BUT I ordered a V belt pully from Surplus Supply with a 22 mm bore to fit the HF shaft , then turn it down on the lathe. It is shown on the pict in my post 47 when I put it on the shaft for a trial fit. I can't find the invoice from surplus for a part no. I just matched the sizes of the metal tipping wheel made from the pully to be the same as the HF roller dies. , . We are now up North, cutting hay, and building on our smaller retirement home. Most of my metal tools are down south where we spend our winters.
powered bead roller??? need help in choosing. tech69 Garage - Tools 0 03-06-2013 12:37 PM
bead roller size freeskier Garage - Tools 0 02-22-2011 07:15 PM
Pinstriping 100 yo bead roller BWS Body - Exterior 4 05-27-2010 04:55 AM
Using a bead roller...backwards... AngliaBob Body - Exterior 2 02-20-2005 08:19 PM
Using a bead roller backwards??? AngliaBob Body - Exterior 0 02-18-2005 06:21 PM
