Converting a car engine to reverse rotation - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2007, 08:46 AM
What all do I need to convert a chevy 350 to reverse rotation? I know I need a crank due to oiling issues. And timing gears marine I think (does anybody know where I can get them). Is there anything elese I need to know.
Old 11-06-2007, 08:57 AM
well?
Does anyone know where I can get a 2 gear timing set?
Old 11-06-2007, 09:02 AM
31 five window
Last journal entry: grill and rear end
Why do you want it to run backwards? Marine application?
Old 11-06-2007, 09:10 AM
well
I am going to mate a 350 to a th-325 4L but it needs to be mounted backwards for weight distribution and you cannot flip the diff because it moves the axles too high and one will hit a main cap. so I am thinking maybee I can make the engine turn backwards thus the car forwards.
Old 11-06-2007, 09:24 AM
31 five window
I was a johnson/evinrude mechanic for over 20 years. Inever worked on their inboard models but do remember seeing them in the service manuals. try checking out a local dealer an older one if possible. They may have some old manuals.If not let me know and I will go to my old place and get info for you.It definitly can and has been done ,but what about the converter and trans working backward?
Old 11-06-2007, 09:27 AM
well
the trans is chain driven so it is to my understanding that it can be done on this trans.
Old 11-06-2007, 09:32 AM
31 five window
What are you building?
Old 11-06-2007, 09:40 AM
well
I allready built a fiero with the 350 and th325 4l in the back and was almost done until I realized the when I flipped the diff the axle hit the main cap.
Old 11-06-2007, 01:25 PM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
The chain drive is after the torque converter. Not sure how the converter is going to like going backwards. I don't think it will work, but you might be able get one custom made. That means the transmission pump will be rotating backwards too.
When you flip the pumpkin, are you swapping axles side to side too? From looking at pictures, I thought the centerline of the axle shafts would be lower than original. Is the axle shaft hitting or the flange that the cv joint attaches to?
Old 11-07-2007, 04:59 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
Pictures man I need Pictures
Old 11-07-2007, 05:07 PM
nitro_baller4692's Avatar
floppers forever
try these guys
http://members.tripod.com/~grannys/generalmotors.html
Old 11-07-2007, 07:52 PM
Vortech 4.3's Avatar
jack of all trades
just get a trans that has 3/4 reverce gears and 1 forward gear. that auta do it.
you can thank me later
Old 11-07-2007, 08:28 PM
You might want to check out a few of the marine engine rebuilders and see where that takes you. A reverse rotation marine block could be the ticket, in long or short block form.
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 04:05 PM
CA smog questions...engine swaps curtis73 Engine 25 11-28-2012 08:11 PM
Cleaned engine with Gunk (didnt cover anything) and car starts, struggles and dies Wahineakua Engine 14 08-07-2007 05:35 AM
streetability? rlackey Engine 45 12-15-2005 01:21 PM
"Basics of Basics" Photographing your car. MARTINSR Hotrodders' Lounge 3 06-01-2005 05:25 PM
