converting a chevy 454 into a 427 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2006, 08:14 PM
Hello,I have the insides for a 427 engine.some 68 L-34 heads and I was wondering,can I take the externally balanced guts out of the 454 and put in my 427 internally balanced crank.And what pistons would I have to use to run on regular pump gas?Carbs,I have a Holley 800 cfm manual choke,and an Edelbrock 750 cfm electric choke which one?The 454 is out of a dumptruck any cam suggestions?Could someone make some sense out of my KAOS?
Old 07-23-2006, 08:08 AM
puting closed chamber heads on a 454
If I put some L-34 heads on a standard 454 with flat top pistons,would it increase compression? A piston manufacterer claims that their pistons can be used with either,is this true with all flat tops? Thanx
Old 07-23-2006, 08:35 AM
Bumpstick's Avatar
Hammer and a torch
On a BBC with flat top pistons the closed chamber heads you get around 8.5-9.0 to 1 compression which is good for street use...
You can use the 427 crank in the 454 block as they are basicly the same block, also the rods will work but if you use the flat top pistons for the 427 stroke you will lose some compression (not much but a little)... Also you say the 454 is out of a dump truck...? I would be sure to check the casting number to make sure of what you have because it may be a tall deck 427 or even a 366...? ID the block and go from there...
454 in 57 Chevy Dingo49 Engine 3 05-25-2006 10:47 AM
1969 427 and 1970 454 camshaft specs sb72elcamino350 Engine 1 10-03-2004 07:11 PM
454 or 427 for 70 Chevelle? f100beatertruck Engine 3 11-25-2003 05:29 PM
427 chevy 71 chevy c-10 Engine 2 12-01-2002 02:29 PM
Chevy 454 marine for the road Si Engine 2 10-10-2002 06:22 AM
