Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Converting from external choke quadrajet to electrical choke quadrajet
Old 10-03-2011, 06:06 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Connect the + wire on Choke to a fused Ignition activated 12V+ source.
Don't tap + wires to Coil or Distributor.
There're 2 different style Choke connectors:
http://www.repairconnector.com/produ...rburetors.html
http://www.repairconnector.com/produ...-GM-Carbs.html
The Coil, Linkage & Cover on Intake can be discarded.
The Vacuum connections should be fairly easy.
