Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - converting fuel injection to carb in 90, 302
Old 04-18-2005, 08:10 PM
Max Keith's Avatar
Max Keith Max Keith is offline
Wiring
You need to get a book with the wiring diagram in it. Go from there.
Curious though, what kind of RPM are you planning to turn that you need a 750 DP? Thats a way too big a carb for a street driven 331, unless you are planning to keep the engine running at about 7000 RPM plus all the time.
What other mods have you made to the engine?
If this is a more or less typical hot street setup, the most you need for a carb is a 600 CFM, and if you are running automatic, a vacuum secondary carb is an almost absolute necessity. A 600 CFM will easily take you out past 7000 RPM. You will find, if this is a street driven vehicle, your lower end power and performance will suffer greatly from running a 750 double pumper.
