Converting fuel injection to carburation? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2006, 10:46 AM
One of the drivetrains I've been thinking of is a Mazda Miata, which is a fuel injected engine, we're not sure we're up to working with fuel injection, it's been suggested to me that you can take an injected engine and convert it to carburation. Does anyone know if this is feasible and if so how big of a project it is?
My daily driver is a Miata and I know these little engines run forever and are very dependable.
Old 01-21-2006, 01:27 PM
I guess I will pass on the 'why' question. If you would like to experiment, you can fit a turbo II 13B rotary engine in your Miata. This is a popular mod people undertake. Very satisfactory results. I drove in one when I used to belong to a rotary Mazda club.
Regards,
Denis
'67 Camaro RS
Old 01-21-2006, 07:17 PM
A company here in Nevada used to install 302 Ford engines and transmissions in them, Monster Miata.
To change one of those engines to carburetted, use the Edcelcbrock manifold and Holley carb, and change the gear to the Motorsport gear on a stock early points/DuraSpark dist and go forward.
GM from EFI to carb., same process.
1960 corvette rochester fuel injection ratlover Engine 9 06-19-2013 08:31 AM
Aftermarket EFI ? x007 Engine 61 02-08-2012 10:38 AM
converting fuel injection to carb in 90, 302 tommygun90 General Rodding Tech 2 04-18-2005 08:10 PM
Fuel Injection vs. Carburetion Mad Maggot Engine 40 01-29-2005 01:09 PM
