Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 12-22-2003, 08:23 PM
Jag Daddy's Avatar
Jag Daddy Jag Daddy is offline
British Style with USA Muscle
Converting Jag rear end to Ford 9"
This is a multi part question so here goes
How had is it to cut down a Ford rear end to make it fit into the Jag rear suspension?
How do they do it? What about mounting the disc brake rotors and calipers?
Second what kind of cost am I looking at to cut one down?
What's the cost to rebuild a Ford rear end.
I'm not in need of it yet BUT I will need to have the one in my car rebuilt sometime and I thought if it's cheap enough I might do the conversion then but have the new unit built now and keep it around just in case.
Regards
Mark
Old 12-22-2003, 11:17 PM
TooMany2count's Avatar
TooMany2count TooMany2count is online now
A Half Crippled Old SOB....
 TooMany2count's barnstar
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
re: Converting Jag rear end to Ford 9"
cant tell ya if its a ford 9inch BUT under the late model lincolns ,mustang & explorer they have IRS in the rear, also there is a company who make a IRS ford 9inch, sorry dont have the info on hand
Old 12-23-2003, 11:45 PM
BillyJoe's Avatar
BillyJoe BillyJoe is offline
As strange as it sounds...I converted my wifes '77 Jag to a Chevy rearend..(couldn't afford to rebuild rearend and do brake job)..anyway this was some time ago and as I recall it was very easy..had to bolt a 2 x 6 tube across the floorpan above rearend and welded tubes through it to run coilover shocks to the rearend and made up some trailing arms. One thing to note..don't use both coilovers from the Jag suspension, maybe try one or use less heavy duty ones. Once you remove the Jag rearend from the bottom of the car you lighten up the back a lot an it will ride like a tank.
Old 12-24-2003, 12:26 PM
walt's Avatar
walt walt is offline
Here ya go...... Heidt's Superide is the best in the business. http://www.heidts.com/heiirs.htm
Old 12-25-2003, 01:03 PM
BillyJoe's Avatar
If I won the national lottery that's the way I'd go too.
Old 12-25-2003, 02:47 PM
Weimer's Avatar
Weimer Weimer is offline
Kenneth Howard hates you...
Jag used Dana third members in their cars, maybe you could find a place that would have a HD/posi unit that bolts right in.
What is the reason for wanting to make the switch?
Later,
WEIMER
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
