converting a manifold to mpfi - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2011, 05:45 PM
Hellbilly Hotrods
ok, so im looking harder and harder at injecting my small block mopar.
i already have a victor jr manifold that has cast in bungs on each runner, intended for either injectors or nitrous nozzles. doing some looking around last night, i came across this. http://www.rossmachineracing.com/injectortool.html
seems like this would be my answer. i have a pretty good drill press, and a full woodshop to make wooden jigs with.
is this a process i could do with normal shop equipment? or is there any other diy way to machine a manifold for injection?
or am i looking to find someone with the equipment and pay him?
michael
Old 11-25-2011, 10:45 PM
Pantaz's Avatar
I've done a couple of manifolds on a manual Bridgeport using common end mills. If I had to do it on a drill press, I would want to build a locating fixture, and add some kind of accurate depth gauge. A dial indicator could probably be rigged up to work well enough -- the dimensions aren't terribly critical.
Also, the drill press spindle should be in very good condition -- axial runout can really mess things up.
The port tool is a much simpler, and faster method, and it's much harder to screw up.
(FYI: Port tools are also commonly used for similar things, such as ports for AN fittings.)
Converting a ported vacuum source to a manifold source Scrumgees Engine 2 08-17-2011 01:09 AM
TBI injectors in MPFI manifold... zildjian4life218 Engine 5 04-12-2011 04:44 PM
Is a MPFI intake manifold worth improving? Mad Maggot Engine 7 05-27-2006 11:18 PM
2.8 Mpfi Shama Jacob Engine 6 02-20-2005 11:03 AM
v6 mpfi to v8 tbi 3rdgencamrs Engine 1 01-04-2005 02:24 PM
