Converting non-AC to AC - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2005, 09:22 PM
Anyone ever converted a 71 Camaro from a non ac to a ac car. I have heard the firewall is cut different. Anyone ever cut one before. Any help would be appreciated as I have purchased the underhood box along with the under dash box from an ac car. My car had no AC. I am also using a 93 LT1 Corvette motor and trans and was wanting to use the condensor and the compressor from that car along with having my lines made at a local AC shop to fit the original evaporator. Any suggestions or comments would be greatly appreciated!!!
Old 09-06-2005, 09:47 PM
ac install
Many moons ago I used to do what you are suggesting- none of them worked out very well, very well may have been my learning curve. I have been told units that have been out/open very long seldom work, I can't say. Even installed factory air in a Porsche 911 against all advice- cutting that firewall was stressful!! Today, several companies make AC install kits, I've tried 6 of them. Vintage Air is the best known, great product. I've used classic auto air on my last two- my current favorite- separate coils. Car before last was a 55 chevy, cooled extremely well, used all the factory engine brackets from a 99 Vortec. If you can borrow/rent the tool, making the lines is a snap, parts are cheap. In Texas, AC is a must. Bill
Old 09-06-2005, 09:59 PM
rrmccabe's Avatar
GM Muscle
Yes, I have done just that on a first generation Camaro. Not the late model motor though.
The opening in the firewall is much bigger on the AC cars. So its a matter of cutting the firewall bigger and replacing all the inside and outside box and duct work with the AC version. Since you have a donor cars parts you have got it made. It would be nice to see the car and make a template for the opening.
Dont forget there are other parts that need changed too. Heater controls as well as wiring changes, blower motor, relay, etc.
Rich
Ideas & Opinions : Placement of Truck Heater & AC Units horvath Interior 26 02-10-2005 02:51 PM
AC regular vs AC platinum vs AC rapidfire plugs ChevelleSS_LS6 Engine 2 10-05-2004 10:00 AM
AC converting from old ac to 134 black66 Electrical 11 03-12-2004 07:26 PM
Need Help With Ac On Sbc!!!!!! hawg082 Engine 2 10-22-2003 12:02 PM
AC advice needed WayOutCat Hotrodders' Lounge 3 09-19-2002 08:50 PM
