Converting points & condenser to elctronics... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2007, 01:30 PM
KENMO's Avatar
St Louis Blues fan....
I have a 1960 Corvette powered by a (1967) 327 small block Chevy... I would like to convert the points & condenser to electronics style.
I've looked into Pertronix and similar Mallory & Crane products. Is their any preference between these similar products?
I'm also considering going the MSD route but not sure what MSD producst I'll need. GM HEI is another option...
Thoughts anyone?
TIA
Ken
Old 08-30-2007, 02:50 PM
summit only goes back to 62' 327 vette so double check to be sure this 67' 327 HEI will fit/clear...
http://store.summitracing.com/partde...116+4294925084
(how good is a GM HEI spark? they are now making/converting them for Fords and Chryslers)
if you gotta have the correct stock dist appearance then the pertronix/crane/etc under cap modules are the choice
Old 08-30-2007, 09:20 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Do you have room for a GM HEI on the block?
If Space is an issue, try Dave's Small Body HEI in Nevada, they make (or can convert yours Cheap enough.)
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-30-2007, 10:23 PM
Points conversion
I recently converted my points distributor over to electronic using the Crane conversion and I am extremely happy with it. What I am extremely happy about is that if for some reason the unit fails when you are out cruisin you can pop in the old points and condenser and continue motoring. Oh bye the way the conversion was on a 1966 SBC 283 in a 28 Model A.
Happy motoring - Jerry
Old 08-31-2007, 06:00 AM
Another option especially if you have the tach drive distributor,is to use the points to trigger an msd box which can be hidden and the system will still apear stock wth all the advantages of the msd.
Old 08-31-2007, 07:41 AM
all of the OEM SS modules are much more "robust" than the pert/crane units which must restrict amps to survive....so a much bigger/stronger spark does occur with a HEI which delivers alot more V and A to the coil......
very very general example:
points=10,000V spark at .035 plug gap
pert/crane=14,000V at .038 gap
HEI=18,000V at .045 gap =more spark surface
definitely are advantages/disadvantages for each......(gotta pertronix on my mild motor daily driver car, $80 vs $350 for a HEI converted Ford dist)....had one that worked great for 10 years with 2.1 ohms total resistance (my own stupid mistake killed it)
ps: you want a GM OEM module in the HEI.....not a made in china piece of crap
lol....carry the whole old points dist in the car....swap it "if" the HEI dies on the side of the road....probably quicker and easier than points swap if you have location marks on the intake and dist body.....any swap on the side of the road will be a pia with the dist in the back
Old 08-31-2007, 09:06 AM
KENMO's Avatar
My tach is driven off of the ignition coil. I have an Accel coil. I've never understood those MSD boxes. With these MSD units doesn't the points and condenser still remain in your distributor? So adding one of these MSD units will not be getting rid of the old points system...
Old 08-31-2007, 09:20 AM
using a msd or other ignition box, the only function of the points becomes a low amp on/off switch signal to the box......
the points "switch" opens and closes to tell the box when to fire "direct" to the coil primary with high volts....
Old 08-31-2007, 10:32 AM
Old 08-31-2007, 11:03 AM
oldred, your (deleted) post comment did come thru to my mailbox....
it has bugged me for years...why doesn't...each oem copy the better parts of their competitors!!!!!
I want a 351W short block with 350 Vortec heads and a Chrysler Torque Flight tranny!!!!
Old 08-31-2007, 01:57 PM
I had misread that post and thought you guys were talking about converting a Ford to the HEI so I thought I would have a little fun with it, but then I saw he was talking about a 'Vette so I guess the joke was on me.
Old 08-31-2007, 03:53 PM
KENMO's Avatar
So there is still wear and tear on your points.... I don't follow the advantage of using a MSD 6AL box... as you are not getting rid of the points and condenser.
My 60 also uses a ballast resisitor...which I believe a HEI or Pertronix solution will get rid of...
Old 08-31-2007, 04:37 PM
not really any wear and tear because the points are not wired to the coil and arcing on every spark event....there is only enough power from the msd box to the points to make a hi/low signal the box can see.....
the coil is connected direct to the msd where it gets zapped with very short duration, multiple 500V charges
no ballast resistor and a low ohms coil is why the HEI makes such a strong spark
the original pertronix (and the crane) do require a ballast resistor.... 1.5ohm minimum for the pertronix, crane spec' is on their site, probably the same....
the "new" pertronix, Ignitor II, (to me), is "to new", to know reliability....it is intended to be used with less ohms (ex:II coil is .6ohm) and make a stronger spark above 3,000rpms
$90 for a HEI vs $90 for a pertronix/crane.....kinda like $90 for a corvette and $90 for a chevette.....they both "will" get you to the store to buy a gallon of milk!...."but" ....
budget $350 minimum to do a msd box by the time you are done....you do need minumum 8mm wires so it doesn't really look stock....
Old 08-31-2007, 05:07 PM
the mallory "E spark" module does also requires a ballast resistor
link to the instructions:
http://www.malloryperformance.com/pdf/6100M.pdf
Old 09-01-2007, 07:59 AM
On the points triggered msd the only wear would be at the rubbing block which if properly lubed will be minimal,the main problem with points is that they arc every time they open and close causing metal transfer and contact wear.This is not the case when used to trigger an msd the points carry almost no current and are simply a ground switch for the box.In this setup a set of points can last for years, and you get a hidden msd system which will outperform any stock ignition out there.
setting points on sb chevy frackster66 Electrical 23 01-07-2014 06:50 PM
If the condenser is bad in a points type dist.would the car run Mr. Wormy Engine 6 08-12-2006 07:23 AM
I need help Converting Ford Points to HEI :confused: bronco69 Electrical 2 05-14-2006 04:45 PM
Points & Condenser r350xx Electrical 3 08-14-2004 11:10 AM
Points and condenser Seon Electrical 4 12-06-2002 07:42 AM
