Converting from points to HEI - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2011, 07:26 PM
sbchevyfan's Avatar
Hi i'm new here but i've already gathered a lot of great information from this site. I'm currently restoring a 1972 Chevy nova that previously had a 250 ci in line 6 with points and im swapping to a 383 with hei. From what Ive read i need to remove a resistor wire from the wiring but im still left with a different plug for the HEI coil than the previous points distributor. how and where would i get the required plug needed for HEI, and is it just a power and ground wire? also i want to add a tach which the car previously didn't have, what kind of wiring would this require? thanks for the help
Old 03-05-2011, 09:32 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
As I remember this is very easy. The power wire uses a common female spade terminal and when I hooked up the tach on my '78 K-10 33yrs ago there is another terminal to hook the tach wire to. Just follow the tach manufactures unstructions on hookup. Should be easy peasy . BTW , there is no ground wire hookup. Of the two terminals on the dist, one is for power and the other for the tach. Also , welcome to the site .
Old 03-05-2011, 11:08 PM
SSedan64's Avatar
Correct^^^. Female spade terminals, like a speaker uses. You can buy the correct HEI Pigtail connectors if you want. They're about $10/pr.
http://www.repairconnector.com/categ...ON-CONNECTORS/
HEI conversion wiring & Info:
http://rmcavoy.freeshell.org/HEI.html
http://www.oldengine.org/unfaq/hei.htm
Old 03-06-2011, 11:27 AM
sbchevyfan's Avatar
thanks alot for the help guys!
Old 03-07-2011, 05:25 AM
I'd buy the correct HEI pigtail for the power wire, since the pigtail has a plastic housing with a positive lock tab that holds it in place. You don't want that power wire falling off the HEI at the wrong time.
Bruce
Old 03-07-2011, 11:38 AM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Bruce
Or a quick walk though a salvage yard with a wire cutter. Probably get it for free at the right place. U-pull- it . Use solder and shrink tubing for a trouble free connection .
Converting to EFI 65fish Engine 12 11-10-2007 07:17 AM
converting from 4X4 to 2WD fred56 Transmission - Rearend 4 10-29-2007 05:12 AM
Converting to E85 Will H Engine 12 09-04-2007 11:42 PM
Converting points & condenser to elctronics... KENMO Electrical 22 09-02-2007 05:03 AM
I need help Converting Ford Points to HEI :confused: bronco69 Electrical 2 05-14-2006 03:45 PM
