converting powerglide torque conv. to T-400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2012, 10:33 PM
327NUT's Avatar
I've been told that this can be done, saves weight and helps with slip at cruise speed. "Built" 507" Cadillac / TH400 in a 2800 lb. '32 Ford, the stock t/c is a very heavy 13" unit, a well respected small converter shop said that they can take an 11" powerglide t/c and convert it from 17 spline to the 30 spline TH400. They add Torrington bearings, set it up for 1800-2200 and generally do all the steps to make it live behind a very torquey engine.
Obvioisly with this size engine and light weight car....which will be a cruiser and not a race car I really don't need much stall, 98% of my driving will be on the highway @ 70 mph, my main interest is 5%-7% slip at cruise speed. Anyone of you trans/TC guys ever done this or heard of doing it, Feasable?
ID:	65723   Click image for larger version
Old 05-30-2012, 02:13 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
why?
drag racers change powerglide convertors to th350/400 convertors. the input shaft is larger diameter and stronger. you hog out the hole in the pump to accommodate the larger shaft.
What you want to do would make the input shaft weaker and you cannot make the hole in the pump smaller. i would imagine you would have to buy a new pump or convert a powerglide pump to fit.
Old 05-30-2012, 05:36 AM
Last journal entry: Some More Roll Cage Fabrication
With a light car you want a higher stall speed to keep from "pulling" through the brakes. I don't know if 1800-2200 would be enough. Talk to some other 32 owners and find out what they run. It is common for t-bucket cars to run 3000 stall with a stock or very mild engine. Reduces pedal effort at stop lights and such.
Good Luck.
Old 05-30-2012, 06:07 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Mixing different converter parts has been performed for decades. The shop should be able to build converter you need for application on the T-400 trans.
The following does not apply to the T-400 in the OP discussion, just an FYI on the power glide shaft tube comment:
Power glide pump stator tube does not need bored out for 30 spline turbo sized shaft. Often the end of the stator support tube is machined out for a bushing to support the end of the turbo splined shaft.
That bushing is needed when the turbine hub inside the converter does not have a bushing on it. With the bushing in place you need to have a shaft with proper holes in it for fluid flow into the converter. You need a busing support on the turbine hub or the input shaft end at the stator tube.
There are larger shafts for the power glide, that can require a full replacement of the stator tube and pump. Must be careful here for proper matching parts
Old 05-30-2012, 06:09 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I have a similar type car with a Cad engine and TH400 and a 13 inch converter. Takes a 2500/3000 stall in these cars. the 10 inch converter can be done but one gets the smaller converter from a chev with the proper spline count to fit the TH400 and then changes the flywheel to one that has the smaller bolt pattern that bolts up the smaller converter. Takes $$$$$ to do this and is not a real advantage unless one is running comp eliminator or something...
Sam
Old 05-30-2012, 10:06 AM
327NUT's Avatar
Ok, thanks gentlemen for the reply's, I'm in no big hurry for this t/c and I'm just kicking a few ideas that I hear about to you guys so I don't have something built that won't fit my appllication. Might have another one for you here before too long.......Dave
Converting Pontiac 400 to Adjustable rockers 68Birdman2 Engine 5 07-21-2010 08:38 AM
converting my 67 impala ss to 350 from powerglide antwonee63 Transmission - Rearend 1 07-18-2010 04:48 AM
Torque Conv shimming question Slomotion34 Transmission - Rearend 4 06-15-2008 07:50 PM
Torque conv. stall? 327NUT Transmission - Rearend 3 01-11-2007 11:41 AM
700R4 torque conv makes camaro overheat J-Dog Transmission - Rearend 3 10-31-2005 08:20 PM
