Converting rear drums to discs - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2003, 03:27 PM
Arrow Converting rear drums to discs
I have a question for you knowledgeable folks.....I am looking for information on how to convert my rear drums, on my 1997 Camaro, to rear discs.its a 3800 sII V6 coupe.
Any help would be appreciated, thanks.
Old 01-14-2003, 05:35 PM
Mrfixmaster's Avatar
Last journal entry: Red, my second T--Bucket
Post
Check your local boneyards, discs were an option, and you should be able to find a rearend with discs and swap them out!
Old 01-15-2003, 01:35 PM
Arrow
Well I was wanting to keep my current axle and just wondering if there is a conversion kit and if so how much (average cost).
Thanks
Old 01-15-2003, 02:56 PM
Post
I would look at a late model Camaro, I install some from a 1999 on my 1975 Nova rear that I am installing in a 1938 Chevy and all I had to do was space the caliper brackets out 1/16 of an inch, all the bolt holes lined right up. Good luck
Old 01-27-2003, 02:29 PM
Chevl_Steve's Avatar
New Member
Post
There has to be companies like MPBRAKES.COM and Stanless Steel and many others making kits. Check the magazine ads.
However, if they were an option for your car like was suggested, go buy the calipers and rotors from a parts house. I have a parts house I prefer and can send you to that has rock bottom prices and name brand stuff most of the time.
You may need a bracket to mount the calipers to. If that part was available stock then it should be available somewhere new or NOS if you can't find it in a junk yard.
If not, I have my 12 bolt in a machine/speed shop right now and they said they'd have no problem fabbing something up right quick to make it work.
Mine didn't come with rear disc, so I have to figure out what caliper to use. If yours did, your decision is easy ....unless you start reading about the guys putting down the design of them and want to look for better.
I have read some suggestions of using recent Camaro or Corvette calipers, and if you have to get something fabbed up to hold them, you can use any caliper you want almost. Just match the rotor you need to it to keep the bolt pattern you need for your wheels.
