converting standard to tilt steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2012, 11:41 PM
Finaling installed tilt steering column in a 87 camaro, the column came out of a 89 camaro , the problem is starting the car, the car starts but the switch action is reversed , the switch slider is different on the tilt column from standard column, Any ideas on making the tilt column work like the standard column when trying to start the car.
Thanks in advance
Old 02-03-2012, 06:21 AM
Do you mean that you turn the switch counterclockwise to start the car? Or are you talking about something else that works in the opposite direction?
The end of the key switch engages a small gear that moves the rack and rod to engage the electrical ignition switch lower in the column. I don't see how the gear could work backwards, but maybe it could if it was assembled wrong.
Bruce
Old 02-03-2012, 06:55 AM
luvbuildingcars's Avatar
Last journal entry: latest incarnation of my 54 ford
some of the gm columns work the opposite way. all you need to do is use the switch (not the key switch) off your old column
Old 02-03-2012, 07:08 AM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
the switch action is the same.. you did something wrong..
the tilt colum uses a different ign switch than a non tilt colummn
if you used the non tilt switch on the tilt column there is your problem
Old 02-03-2012, 07:58 AM
converting standard steering to tilt
Bruce
Yes thats whats happening
Old 02-03-2012, 08:03 AM
I used the slider off the old column , had to get a new key made.
thanks for the reply
Old 02-03-2012, 08:07 AM
Which switch are you talking about ? slider or ignition switch ?
Old 02-03-2012, 08:20 AM
switch action, you mean slider switch ? just added used column, orignal slider switch still in car , a new key
Old 02-03-2012, 08:47 AM
Bruce
I did have another mechanic take it apart before it was installed , maybe he assembled it wrong.
Old 02-03-2012, 05:15 PM
on the non tilt column , the rod that activate the slider switch goes away from the switch, on the tilt column the rod comes toward you, what can I change to make it work.
Old 02-03-2012, 05:33 PM
stich626's Avatar
gearheadslife
the correct ign switch,, not the lock.. not the rods the switch
f bodys have 4
non tilt, manual
non tilt auto
tilt manual
tilt auto
all bets are off if the lock cyl. and that gear and rod systems been screwed with.. from say a theft. and put back together incorrectly
my bet is you have a non tilt switch on the tilt column
but not being there.. can't tell from here..
Old 02-03-2012, 06:19 PM
f bodys have 4
non tilt, manual
non tilt auto
tilt manual
tilt auto
can the switch be changed ? I pick up a tilt column from pick a part, had a key made, tried 2 different tilt columns,
Old 02-03-2012, 06:55 PM
stich626's Avatar
gearheadslife
are u useing the switch that came on the column. (at bottom and you plug in a farly long plug) or the one off the column you took out of the car..
if you're use'n the one that came wit the j/y column. it should work correctly.. you do have the key on the right side not the left
Old 02-04-2012, 10:03 PM
i hook up the tilt column with standard switch , not good , more R & D to come !
Old 02-04-2012, 10:05 PM
f bodys have 4
non tilt, manual
non tilt auto
tilt manual
tilt auto
Thanks for the info
Converting non-tilt buckets to tilting SUX 2BU Interior 1 09-29-2011 09:02 AM
Converting late model 98 block to standard oil filter fitting TNshadetree Engine 5 07-03-2009 09:00 AM
converting an 86 302 auto to a standard shift 59 wagon man Hotrodding Basics 1 02-10-2008 02:03 PM
Converting an LT1 to Carb and standard Dist. lonewolf867 Engine 3 09-18-2007 01:00 AM
converting standard brakes to power on a 55 belair Randal4h Suspension - Brakes - Steering 5 09-15-2003 12:45 PM
