Converting wheel bearings taper to ball - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2007, 02:49 PM
Im a lil new to land speed suspension and am converting a Mustang II hub over to ball bearing to drop some friction.
Do you know of anybody that might help me find a conversion bearing.
Im using Wilwood Mustang II hubs with Hiedts MSII spindles if it matters.
Old 10-11-2007, 03:51 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Just from common sense experience; a ball type bearing won't fit where a tapered roller setup was...there is not enough room. The diameter of the balls need to be of a certain diameter for the expected loads.
Example: The old VW bugs were ball bearing fronts until 66 when they went to tapered roller. The size of the outer races were dramatically reduced in 66, because a tapered roller supports more load due to the width of the rollers, and then the rollers can then be much smaller in OD than a ball.
So if you are stuck with the original rotor bearing race bore, there just won't be enough room.
Old 10-11-2007, 10:45 PM
I hear you f&J,
I know there are guys running balls but not sure what they are doing to get them to fit. Like you said I can get my ID but then my OD is too large .
Ill hope some one chimes in while I search some.
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 09:38 PM
wheel bearings stoney 81ta Suspension - Brakes - Steering 2 03-20-2004 05:56 AM
packing wheel bearings chevynut1 Suspension - Brakes - Steering 12 01-10-2004 06:58 AM
Front Wheel Bearings black66 Suspension - Brakes - Steering 10 06-02-2003 08:31 PM
Bleeding Wheel cylinder on a 91 corolla ramvrao Suspension - Brakes - Steering 1 03-20-2003 03:38 PM
