Coolant - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2009, 03:02 PM
Coolant
New member, howdy all.
Quick question, have a 55 Ford F100, bought off ebay, probably first mistake ?? It has a rebuilt 77 302, lost 3 freeze plugs out of it while running it in the gargage over winter. Anyways finally got them replaced. The problem now is refilling the coolant. The previous owner didnt know the size of the radiator. He recommended pulling the thermostat, run the truck and fill the radiator. Turn it off drain the fluid in containers, keep half, put back in the truck and fill the rest with anti-freeze.
My question, is there not a easier way of doing this or is this it ?
I appreciate any feed back.
Token
Old 05-06-2009, 05:03 PM
Mad_Max's Avatar
Sounds like too much work to me. Either get 50/50 premix or buy a gallon and mix it yourself. I'm assuming theres nothing in it for coolant, so toss a gallon of 50/50 in it, then another till its close to full. Start it up, let it warm so the tstat will open then top it off after it cools.
Coolant Dilemma! Ok to use Green coolant with Red coolant? mgold Hotrodding Basics 6 03-31-2009 05:37 PM
overflowing coolant. TVR383 Engine 8 09-12-2006 03:18 PM
Fomoco Antifreeze MI2600 Engine 15 04-02-2006 12:38 PM
How the coolant ended up in the oil (an update) blndweasel Engine 1 06-19-2005 11:24 AM
