coolant block drain plug - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2004, 12:57 AM
jwash56's Avatar
where is the coolant drain plug located on the block of a 350 olds?
thanks,
john
Old 04-20-2004, 01:04 AM
montea's Avatar
tryn to learn
on each side of the block near the bottom in the center?
Old 04-20-2004, 12:26 PM
jwash56's Avatar
i didn't see the coolant drain plugs anywhere near the center of the block on both sides. could they be anywhere else on the block? i only saw freeze plugs.
Old 04-21-2004, 03:14 PM
Siggy_Freud's Avatar
It should be down closer towards the starter. Its fairly close to an exhaust port towards the back of the engine. Depending on what you have for exhaust (manifold or headers) you might need to get under the vehicle to see it.
Bringing history and technology together.
Old 04-21-2004, 05:42 PM
Tazz
block coolant drain plug?
I don't believe there is any other coolant drain but the one on the bottom of the radiator.
Tazz
Rat Rods Rule!
Old 04-21-2004, 09:33 PM
jwash56's Avatar
if there is only the radiator drain plug how will i drain the block?
Old 04-21-2004, 11:25 PM
Do you have a coolant temp sensor in the side of your block? If so, thats your drain point for the block.
Old 04-21-2004, 11:47 PM
jwash56's Avatar
no...i don't think i have a temp sensor on the block.
Old 04-25-2004, 04:27 PM
Tazz
drain that block
is the block still in the car? did you pull the water pump yet? are you leaving the trans attached to the block?
Tazz
Rat Rods rule!
Old 04-25-2004, 04:33 PM
what is the reason you need to completly drain the block???
Jesse
