Put a hose from the intake to the water pump.
The Block has a Bypass for the Pump, "hole below left lower WP mounting bolt">> http://www.chevytech.info/2c42o8.html
You could drill 2 or 3, 1/8" holes in the Thermostat to help aid the bypass and just plug the WP & Manifold ports. |
It is better to have a hose looped(not for looks I agree) . hook from the intake to the water pump with it. Water circulates through there as the engine warms up an running a hose would keep the engine from developing a hot spot because of no flow.wich it what you will have with no heater hose and a thermostat closed.
| Coolant Dilemma! Ok to use Green coolant with Red coolant? | mgold | Hotrodding Basics | 6 | 03-31-2009 04:37 PM |
| getting to the response | plym hoover | Hotrodders' Lounge | 3 | 05-10-2006 12:07 AM |
| water circulation problem | cboy | Engine | 12 | 04-27-2006 09:21 AM |
| Quick coolant question | 78 monte | Engine | 2 | 11-24-2005 09:47 AM |
| Circulation | Thom Laybourne | Engine | 6 | 09-10-2004 02:59 PM |
