Coolant drain question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2006, 12:46 AM
trenchdog73's Avatar
J Smith
On a chivy 350 in a 73 nova with a radiators with no petcock, What is the easiest/least messy way to drain the necessary coolant for a intake manifold swap?
Old 04-07-2006, 01:00 AM
Super Chevy's Avatar
BRB carring
id pull the lower rad hose off the rad and just have a nice size catch pan underneith it. but no matter what there will still be some coolant in the thermostat housing, just put some towels around it when you pull it off.
Once you go flat black you never go back.
1966 El Camino
1992 Dodge Shadow
1986 S-10 Blazer 4x4 Hot Rod
1970 Chevelle
1966 Chevelle 4 door
Home Made Go Cart
Old 04-07-2006, 02:09 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Drain the block by removing the plug on th eside. THEN remove the bottom radiator hose.
Old 04-07-2006, 02:19 AM
Siggy_Freud's Avatar
I pull off the top radiator hose and bend it so that the coolant left in it drains. Then I pull the heater hose that runs to the intake manifold and let the manifold drain. It might take a second to see what path the coolant takes but you'll be able to catch it. You might still have a bit left, but if you control the intake manifold removal you'll be okay. I have pets so I always use Pet Safe antifreeze just to be on the safe side.
Bringing history and technology together.
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
coolant block drain plug jwash56 Hotrodding Basics 9 04-25-2004 03:33 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
