Coolant Drip/Milky Oil/Good Compression - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2007, 02:54 PM
Mercurymarc
I have searched the archives and found several helpful threads but still need your help. I rebuilt my 1969 Ford 250 Straight Six 15 months ago and have a persistant tiny coolant leak on the right front of the block- looks like it is from the head-block seam near the front (#1). Also my oil looks like chocolate milk. Runs a little rough but not too bad, doesn't burn oil. Compression tested today- good results (162-180 PSI). I would prefer not to to pull the head (just yet anyway) but I think I have gasket leak between the coolant passage and oil passage and also a leak through the gasket to the block-head junction. (I probably should have had at least the head checked and milled flat before I slapped it together...).
Wondering if any cures in a bottle might work?
Thanks!!
Marc in SF
1963 Mercury Comet Ragtop w/1969 I6 250
http://mercurycomet.net
Old 03-11-2007, 03:12 PM
if you ran the engine any amount of time with chocolate milk oil, the bearings are probably shot now
Old 03-11-2007, 06:31 PM
Mercurymarc
Ouch! What if the oil looked more like a rootbeer float; more like amber-brown fluild with a brownish thick tint, not entirely transparent?
Thanks
Marc in SF
Old 03-11-2007, 07:02 PM
WDCreech's Avatar
Grumpy Old Goat Herder
If it doesn't look like motor oil, it's time to tear it down, fix the problem, and change the bearings before the engine gets some unrepairable damage.
Old 03-11-2007, 07:07 PM
poncho62's Avatar
Wiki Edits: 5
Coolant has been mixing with the oil, as you suspected.........Most likely the head gasket. Not hard to change on a six. Like said, you have to wonder if the bearings have been damaged?
As Clint Eastwood says....."Do you feel lucky?"
I would pull the pan.
Ontario Rodders
Old 03-11-2007, 08:14 PM
Classix_Lover's Avatar
Music soothes the soul
Last journal entry: Wiring finished finally
I would suspect a possible intake gasket failure. Either way, you're going to have to first inspect your bearings to see if they need to be replaced.
Old 03-11-2007, 08:20 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Yeppers...it sounds like a leaking head gasket....antifreeze does not do bearings anygood either. I think you should replace the head gasket and its gonna be a gamble if you don't change the engine bearings...I believe I would change them.
Old 03-11-2007, 09:15 PM
WDCreech's Avatar
And as you said yourself, have the head and deck surfaces checked to make sure thay're flat.
Bill
Compression question for the Pro engine builders.. Axelrod Engine 14 01-16-2007 10:29 AM
overflowing coolant. TVR383 Engine 8 09-12-2006 02:18 PM
Compression concerns. Siggy_Freud Engine 4 07-11-2006 10:06 AM
Whats the correct temperature my 350 should be running at? batman09 Engine 101 10-23-2005 12:29 PM
How the coolant ended up in the oil (an update) blndweasel Engine 1 06-19-2005 10:24 AM
