coolant leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2009, 11:30 AM
brian12c's Avatar
coolant leak
I overhauled the 350 in my 91 gmc 1500 about 300 miles ago and I have a coolant leak that I assume is seeping from the back of the block somewhere. The dust cover is slowly dripping coolant out the hole in the bottom. If it is a leak in the back of the block, do you think radiator stop leak would fix it? Any other ideas? Thanks BF
Old 04-29-2009, 04:07 PM
fast68's Avatar
likes chevy trucks & boobies
the most common water leak on the tbi engines is intake manifold gasket corners
check those for wetness.
we have had to do many
Old 04-29-2009, 10:48 PM
most leaks are the intake gasket, leaks out of the rear as fast68 said, but if you just rebuilt it maybe you didn't torque the intake manifold right? you should put a coolant pressure tester on it and find out what is leaking.best bet its the intake like fast68 said, i have done about 40 of these intake jobs on tbi small block chevys from coolant leaks. stop leak will just be a temporary fix. hope its not a freeze plug on the back of the block.if so cheap fix is to use iron-tight.
Old 04-30-2009, 12:52 PM
There's soft plug on each side of the block behind the flywheel/flex-plate; hopefully, they were replaced and sealed with your rebuild.
Bogie
Old 04-30-2009, 05:38 PM
T-bucket23's Avatar
Wiki Edits: 26
Those also have those crappy connections on the manifold for the heater hoses. They can dribble a little and run down the back of the block. A good pressure tester should help find the issue. The intake is also real common but new gaskets, especially if you used the real GM gaskets usually wont leak.
Dont put stopleak in it. Find the issue and fix it.
Chet
Old 04-30-2009, 07:18 PM
fast68's Avatar
please learn me about iron tight for my general knowlede purposes thanks never heard of it.
BB Chevy Coolant Leak @ Water Pump leejoy Engine 3 07-04-2006 02:10 PM
coolant leak. TVR383 Engine 6 07-03-2006 01:45 AM
Whats the correct temperature my 350 should be running at? batman09 Engine 101 10-23-2005 01:29 PM
coolant leak mitmaks General Rodding Tech 5 08-20-2005 08:03 PM
305 coolant leak? 72superbug Engine 1 02-09-2004 08:31 PM
