COOLANT IN THE OIL 5.3 motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-29-2012, 03:52 PM
Hey guys, im working on a 00 silverado 5.3 motor thats using coolant too fast. I change the oil in it two days ago and it had water or coolant in the oil !! The truck never ran hot as long as I had it. IM HOPING ITS NOT A BLOWN HEAD
Old 02-29-2012, 04:17 PM
Last journal entry: My Last Hot Rod
Better get it fixed
I ran my Escort that way and lost the engine eventually it was a cracked head on mine, White fluff in the oil was antifreeze and water
Old 02-29-2012, 04:39 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Look it over well. Most likely is a intake gaskets puking out.Pretty common on those.
Old 02-29-2012, 04:53 PM
T-bucket23's Avatar
Wiki Edits: 26
X2 on the intake. I have take them apart and the engine was full of milk shake right up to the intake runners.
If you keep running it you will destroy the bearings
Chet
Old 02-29-2012, 06:28 PM
Last journal entry: Some More Roll Cage Fabrication
There is no coolant passages in the intake of the 5.3 vortecs(LQ4). Check the head gaskets and the heads very close. I've replaced a few gaskets for coolant loss without any overheats.
Good Luck
Old 02-29-2012, 07:00 PM
BOBCRMAN@aol.com's Avatar
Only place coolant is slippery is the floor..
WHEN you pull the heads. Have them checked for warp/flat. AND have them pressure checked.
I get a lot of these that are cracked along the upper row of head bolts. Topside, where the casting is machined for the head of the bolt. HARD to find with naked eye. But, bubbles like crazy with p-check..
Old 03-01-2012, 05:24 PM
LATECH's Avatar
Good Luck
My bad, you are correct.
Fact is the Gen III doesnt even look like a chevrolet.
The LQ4 would be the RPO for the 6.0 litre also.
Old 03-01-2012, 05:44 PM
check intake manifold its a common gm screw job on those motors
Old 03-01-2012, 05:55 PM
Yep...should have said LM4 or one of the 6 others. I only remember LQ4 because that is what my Father in law has and im always working on it.
Either way he needs to look at the head gaskets and/or heads for the coolant leak.
Old 03-01-2012, 06:01 PM
LATECH's Avatar
I agree. After checking the differences in the sbc i see what you are talking about. You are correct.
I work on so many different cars that I really dont even pay much attention to them. Only when I am assembling one, after that its 5:00 somewhere...LOL.
Its getting to be there are as many different SBCs as there are carmakers.
Old 03-04-2012, 11:16 AM
GM head gaskets
I see I wasn't the only one to experience those wonderful engineers designs, but I had 150 K on mine when it started to do the same, It was less money to buy a 2002 running take out with low mileage.
Old 03-07-2012, 07:31 AM
Last journal entry: My 1979 Caprice Project
There were some early GenIII heads that leaked coolant near the front and rear drain backs. The water jacket wall got a little thin and had porosity issues. What casting number are the heads? The last 3 digits of the casting number should be visible above the exhaust flange. It's cast in, not stamped or etched. should be could be 706 or 753, or something like that. Either way, it's time to pull the motor. If you have that much white stuff, it's likely you have some damage to the bearings. It's good insurance to pull it apart and check before the crank gets chewed up. Good news is that 5.3's are pretty darn cheap in the boneyard. I picked a good one up with a bad lifter for $200. Guy thought it had a spun bearing, but the journals are great.
Old 03-08-2012, 10:31 PM
Yea I thought it would be that the heads were cracked too because the new style LS motor don't have water going through the intake. I pressure test it and it didn't leak down so ima do a head job and hope I can save my baby THANKS GUY
Old 03-09-2012, 12:14 AM
New Member
'73 Olds 350 Oil in coolant no coolant in oil :( DQ81 Engine 4 09-28-2011 07:46 PM
red coolant mitmaks Engine 6 08-30-2010 07:43 PM
Coolant Dilemma! Ok to use Green coolant with Red coolant? mgold Hotrodding Basics 6 03-31-2009 04:37 PM
coolant mitmaks General Rodding Tech 1 05-17-2008 10:45 AM
npg coolant mancinator Engine 0 07-09-2004 01:58 PM
