coolant problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2008, 05:08 PM
untchable502's Avatar
coolant problem
i have a 82 camaro z-28 with a freshly built mild 350 in it, it hasn't hit really extreme high temps yet the highest i seen it was at 220 with in city driving and alot of idling, it has a 18 in flex a lite fan on it, my thought were maybe adding an addtional electric fan to it with a thermostatic switch would that be blocking my radiator if i did that, or maybe i should just switch to a electric fan all together, or maybe my flex a lite fan should have a clutch on it????? any ideas or suggestions would be great, what have you other third gen camaro guys done???
Old 06-08-2008, 05:38 PM
Jmark's Avatar
It's really hard to beat a good working STOCK type fan clutch and STOCK 7 blade fan, with a shroud.
Your temps are not hot, but it's your call. Personally, I don't worry until it gets to 230-240. Sometimes we end up trying to "fix" something that really doesn't need fixing! LOL
Mark
Old 06-08-2008, 06:18 PM
sensor location
Along the same thread,what are the opinions of some of you on where a coolant sensor should be located, on the intake manifold or in the cylinder head? thanks in advance, Keith
Old 06-08-2008, 08:35 PM
lonewolf3197's Avatar
Chief Petty Officer, USN
Last journal entry: My Monte Carlo
Are you running it with a shroud? 3rd gen Camaros don't cool worth a damn without one. My 86 had cooling problems with a flex fan because there was no shroud with it. I put an electric fan pushing through the radiator and it solved the problem. I was lucky to see over 195 on the stock temp gauge. Very few, if any 3rd gen V-8 Camaros came from the factory with a clutch fan, so that can be a difficult route. Not sure if that is 100% accurate, but niether my 84 or 86 had a clutch fan. If you have any other 3rd gen questions let me know. 2 of my 5 Camaro's were 3rd gen. Later
The Wolf
Old 06-09-2008, 12:12 AM
malc's Avatar
Living At The Speed Of Life
I have a 350 in a 1986 Camaro.
After various setups I ended up making a complete enclosed shroud with dual electric fans.
The fan switch is in the manifold, clumsy me had broken two while removing spark plugs.
Make sure your airdam is in place.
Old 06-09-2008, 12:42 AM
SSedan64's Avatar
Malc you should put a wide rubber flap across the bottom section. When at highway speed the air will push it open for more flow. When in stop & go traffic the fan will pull it closed so all air goes through the fan. It helps.
Old 06-09-2008, 01:07 AM
malc's Avatar
I know, at the moment I have too much other stuff to do.
I was going to look for some flaps off a VW Golf or something similar.
I should also add sides in front of the rad to direct all the air through it.
I´d like a deeper air dam as well but as the car is lowered I´d lose ground clearance.
At the moment it runs at 190º average, sometimes going to 200º.
I was going to 220º previous to the duals and shroud and the car acted up terrible in traffic.
Old 06-09-2008, 01:19 AM
SSedan64's Avatar
Nice Shroud
The shroud looks very nice. Your right about directing the airflow it makes a lot of difference. Friend of mine was running a 76 Camaro oval track car with just a ford 6 cyl. solid 4 blade fan. Made him a shroud & ducts in front of Rad & below bumper, no cooling problems since.
Old 06-09-2008, 01:49 AM
malc's Avatar
I made the shroud as deep as I could so the air could move around.
Tight fit or ?
(The belt on the alternator has since been adjusted.)
Old 06-09-2008, 04:02 AM
SSedan64's Avatar
Looks good, with the extra space it should pull air from more of the Radiator surface.
blower idle rpm problem Ratoflic Engine 7 12-01-2008 03:31 AM
over heating? jo5hi3 Engine 24 06-09-2008 03:16 PM
Yargh, carbureator problem is driving me nuts (but not my car!) caustic meatloaf Engine 12 05-21-2006 12:41 PM
Temperature Sending Unit problem Centerline Engine 3 11-12-2004 05:13 PM
Mysterious coolant loss DoubleVision Engine 11 10-21-2003 01:13 AM
