coolant recovery can - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2010, 09:32 PM
Is the coolant recovery resevior actually even needed?
Old 12-02-2010, 09:36 PM
BOBCRMAN@aol.com's Avatar
Modern systems rely on it. Drag race motors need it. The tech guy at the track gets real testy when he has to clean up your "Burps"...
Old 12-02-2010, 09:38 PM
is it safe to say a 77 sbc street mod car would be ok without it
Old 12-02-2010, 09:52 PM
001mustang's Avatar
I recently modified 66 GMC truck to recover coolant in order to minimize oxidation and acid formation inside coolant system.
Old 12-03-2010, 05:35 AM
With high cooling system temps and a high pressure cap, you need to have somewhere for the anti-freeze to go as the engine heats up. The recovery tanks allows it to expand into the tank when hot, and then be drawn back into the radiator as it cools. Without the tank you will just push coolant out on the ground, and you will need to add coolant back in when the engine cools. If you have no recovery tank and don't check the coolant frequently, you will probably end up overheating the engine from low coolant.
Bruce
Old 12-03-2010, 05:42 AM
Wiki Edits: 27
Can do help
Old style radiators had a large top tank and space for expansion and you left a 1 in air space at the top. .When detroit changed to cross flow radiators the expansion area no longer existed and an overflow-expansion tank is required. also on a lot of cars the heater core and hoses are higher than the colant filler so you need a tank so when the system burpes out the air coolant can replace the air.
Old 01-26-2011, 07:48 PM
Last journal entry: 1949 Chevy PU 3/4t barn find
Different types of cans
What is the difference between "Recirculating catch can", "Catch can", "Expansion tank", "Overflow can","Overflow tank", "Recirculating/overflow catch can"???. All of these are listed in Summit. I will have a 383 in a 50 chevy pickup. What is needed?
Old 01-26-2011, 08:29 PM
001mustang's Avatar
My coolant recovery overflow expansion tank has an internal vent tube that extends almost to top of recovery tank. Coolant is never lost, just goes from radiator to recovery tank, recovery tank to radiator, repeat.
Name:	0 rec `n fil.jpg
ID:	51944   Click image for larger version
Name:	0 rec bracket.jpg
ID:	51945   Click image for larger version
Name:	0 recovery.jpg
ID:	51946   Click image for larger version
How Does A Thermostat Work? cobalt327 Hotrodding Basics 16 03-16-2010 06:32 AM
Coolant Dilemma! Ok to use Green coolant with Red coolant? mgold Hotrodding Basics 6 03-31-2009 04:37 PM
Whats the correct temperature my 350 should be running at? batman09 Engine 101 10-23-2005 12:29 PM
How the coolant ended up in the oil (an update) blndweasel Engine 1 06-19-2005 10:24 AM
