Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Coolant recovery tank
Old 10-03-2013, 03:39 PM
rustman rustman is offline
Now I see why your the #1 techinspector. If I have coolant up to the top of the overflow tube and the radiator dumps hot water into the tank it's going out the tube onto the ground so that recovery tank water level stays the same. The water level in the radiator drops until it is no longer expanding into the recovery tank and by then I am running hot. Thank you.
