Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Coolant recovery tank
Old 10-03-2013, 05:08 PM
Irelands child's Avatar
Irelands child Irelands child is offline
These gadgets usually come without any sort of instruction so you are supposed to know how, as an automobile enthusiast, to install them - wrong!!!
You have to open the cover, see which tube inside is the short one and then attach the radiator overflow line to it - the long tube inside dumps to the ground in case that tank completely overflows. If you hook it up the other way, goodby coolant (ask me how I know this - yep, a senior moment).
Fill the radiator - the tank will just recover the fluid pushed out for whatever reason then it will eventually siphon back to the radiator as long as you have a pressure cap on the system
Irelands child
