-   -   Coolant recovery tank location (http://www.hotrodders.com/forum/coolant-recovery-tank-location-228916.html)
rustman 01-28-2013 02:05 PM
Can anyone tell if a coolant recovery tank can be mounted below the radiator? The radiator vertical flow. Thanks.
33Willys77 01-28-2013 02:16 PM
I have mounted several like that. The pressure (when the coolant gets hot) will force the coolant into the overflow tank, and when needed, it will pull it back in. It does not depend on gravity.
rustman 01-28-2013 03:42 PM
Thank you for the information.
