Coolant recovery tank location - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2013, 02:05 PM
Can anyone tell if a coolant recovery tank can be mounted below the radiator? The radiator vertical flow. Thanks.
Old 01-28-2013, 02:16 PM
33Willys77's Avatar
I have mounted several like that. The pressure (when the coolant gets hot) will force the coolant into the overflow tank, and when needed, it will pull it back in. It does not depend on gravity.
Old 01-28-2013, 03:42 PM
Thank you for the information.
Coolant Recovery Tank Install 64Joker Engine 1 07-15-2012 11:40 AM
coolant recovery can novaguy77 Engine 7 01-26-2011 08:29 PM
SBC coolant sensor location 84TA406 Engine 1 09-29-2009 03:22 PM
Plumbing a coolant surge tank - need help heyjude076 Engine 10 09-13-2007 07:31 PM
SBC...Where is the coolant Sensor location... doo600 Engine 6 07-18-2006 04:41 PM
