Coolant sensors - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2013, 01:23 PM
frickenbored's Avatar
383!
Coolant sensors
Alright so I'm finally going to put my electric cooling fans on a thermal switch after forgetting to turn them on a couple of times...
I bought a kit from summit racing that has the relay, circuit breaker, temp sensor ect, my question is where is the best place to put the temp sensor?
The truck is a 1988 K5 blazer with a built 350 (1969 block, 1972 heads, edelbrock performer intake, holley 770 carb)
There are only two coolant ports on the engine. The coolant temp gauge is in the driver side head, and there is one more port next to the thermostat housing. My question is would the fan sensor do better in the head or intake? BTW the kit turns the fans on at 190 degrees and off at 170 degrees.
Old 04-14-2013, 01:33 PM
WDCreech's Avatar
Grumpy Old Goat Herder
The port next to the thermostat will react to the water temperature after it has past completely through the engine. That is where I have mine.
Bill
Old 04-14-2013, 05:32 PM
sedanbob's Avatar
Agree with Bill - that's where mine is too.
Old 04-14-2013, 05:40 PM
LATECH's Avatar
X 3 ............
Fact is stranger than Fiction
Coolant bottle overflows; also losing coolant 35benzman Engine 5 06-19-2012 08:48 AM
What O2 sensors should I buy Silver Surfer Engine 4 05-15-2011 08:03 AM
Coolant Dilemma! Ok to use Green coolant with Red coolant? mgold Hotrodding Basics 6 03-31-2009 04:37 PM
Sensors fatdawgy Introduce Yourself 1 08-13-2007 12:54 AM
Sensors woodmanscott@hotmail Engine 4 03-11-2007 01:27 AM
