Coolant Temp Sender on a 1992 S10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2007, 06:25 PM
Overdriv's Avatar
2.8L is a one wire sensor. Went to buy new sensor and the only thing available is a two wire. Went to GM dealer, same thing. What am I suppose to do with the extra wire? Is it a ground? Ignore it?
Old 01-16-2007, 06:44 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
there should be 2 different ones. A coolant sensor that runs the ECM and a water temp sending unit that works the gauge or light in the dash. You might be asking for the wrong one.
Old 01-16-2007, 07:12 PM
Overdriv's Avatar
You are very possibly correct. I never thought about it as I'm not using the two wire sensor that went to the computer. The gage is just a one wire with ground reference through the body of the sensor. I'll go back and see what they have to say.
Thanks.
Old 01-16-2007, 07:56 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Tell them that you want a temp sending unit for a guage instead of a coolant sensor.
Old 01-17-2007, 09:48 PM
Overdriv's Avatar
The parts stores, NAPA, AutoZone and the local dealer say the one wire sensor has been replaced by a two wire sensor. I took the wiring book with me today to the dealer. Showed him the (sensor/sending unit/switch, whatever you want to call it), I wanted. He came up with a different part #, but still said it was a two wire sending unit. He also said the description stated it could also be used as a one wire sender. If that is the case then it will have to have an internal ground reference to work as a one wire sender. He said no, the other pin is the grd. He is going to get one and I will check it out to see just what it is. I don't think the parts man knows what he's talking about. If it does have an internal ground, I'll just drill out my existing connector and be done with it. I can't see a two pin sender having a ground reference to the body and a second pin for ground also?? It would make it kind of universal, but??
I don't want to run a ground wire as all the engine wiring is finished and in conduit. I should have gotten the sender long ago, but who'd have thunk.
BTW, the GM wiring schematic book calls the computer sensor a "coolant temp sensor". It calls the gage sending unit a "coolant temp switch".
ETA: I was hoping someone had run into this before and could give me a part number for the correct part.
Old 01-18-2007, 05:04 AM
I ran into this on my kids 88 s10, one terminal on the switch was for a warning lamp and the other ran the gauge.The way ifigured it out was I had the terminals reversed and the warning light got brighter as the engine warmed up and the gauge was inop.reversed connections and all was well.So you will have to figue which wire is to the gauge and hook it to the sending unit leaving the warning light disconnected.
Old 01-18-2007, 05:07 AM
Just reread your post try a temp sensor from an 88 4.3 should have both terminals, They are ordering the idiot light swith, the clue is it says temp switch not temp sender or sensor . That should mean it is the one for idiot light not gauge package.
Old 01-18-2007, 09:01 AM
Overdriv's Avatar
The original setup with the 2.8L engine in the S10 was a edgewise analog gage. There is no water temp light. The connector to the original device has just one wire. In the wiring schematic book the coolant temp switch is shown as a variable resistive device, a jagged line with an arrow across it. A switch for a light wouldn't be depicted as such.
Regardless what it's called, I need a one wire device to run an analog gage.
Old 01-18-2007, 12:34 PM
Lost in the 60's
Wiki Edits: 4
I just looked it up at Napa auto parts on-line. It shows two one for $13.49 and another one for $21.49. They are calling it a engine temperature guage switch. I cannot tell about the wires in the picture. It says it is for a 92 S-10 with a 2.8 engine with a guage though. Check it out . http://www.napaautoparts.com/masterp...itch&VehCode=Y
Old 01-18-2007, 02:27 PM
Overdriv's Avatar
Henry, thanks for the effort. Those two senders look just like the one I got today from GM dealer. A one wire sender with a divider in it. It will work as I got a new connector and wire with it. It was just a matter of getting them to look for the right thing and calling it a switch.
Thanks for all the help guys!
water temp sender resistance curve jparkes57 Electrical 7 09-26-2012 05:17 PM
tranny cooler spokesc Hotrodding Basics 22 12-23-2005 10:49 AM
Whats the correct temperature my 350 should be running at? batman09 Engine 101 10-23-2005 12:29 PM
can I remove stock temp light sender? earthworm Engine 8 09-12-2005 09:32 PM
Aftermarket Temp Sender? Seon Engine 11 10-29-2004 08:31 PM
