alum heads
I have a p/u with 383 sbc with alum heads n a 67 Camaro 496 with alum heads.
On both the fans come on as soon as I turn the ign on, n they always stay on I like to see at least 190 temp no more than 210 max both have the biggest alum radiators I could get in there. I know what u mean about ambient temp,I live in coastal Alabama n it gets very hot here too |
Your fans could actually be limiting airflow at cruise. Did you change anything else.
What is your timing set at. Retarded timing can cause what you are talking about as well. 210 is not really in the danger zone. Does it top out at 210 or does it keep climbing.
Artificial Intelligence is no match for Natural Stupidity Chet |
T bucket is right in saying the best set up is a factory clutch fan (out of a diesel truck is best) and a big radiator is not such a bad idea either.
Sometimes its better to stick with what youve got. the statament that your fans could be blocking the air is also right I didnt remember where your fans are mounted front or rear of rad. Did u drill a bleed hole in the thermostat? Max timing I run in my big block is 38 all in by 2800 running 15 initial n the rest mechanical (no vacumm) If your fans are cooling the engine when you are stopped it tells me you have a problem either with the fans actually blocking the air at cruise or an air flow problem under the car at speed(I.e. air blowing backwards from increased air pressure under chassis) For air flow I check with water manometer behind radiator and also in engine compartment and in front of radiator in order to get delta p across radiator at different speeds,if you dont live too far from me I have the equipment to do this, n ill be glad to help you out,no charge. Ive already got all the work I can stand building motors |
Heating at road speed is indicative of insufficient flow through the radiator. You just have to find the restriction. Before I would do anything else, I'd make a couple of 1" or 1 1/2" wood spacers to put between the hood hinge and the hood, so that the hood sits up higher in the back and allows underhood air to escape. It's nearly free and converts back to stock simply and easily, so why not try it?
Continue to do your troubleshooting of the cooling system, but also make another check.
I assume you are running a carburetor. However, I would recommend installing an O2 sensor and AFR gauge so that you can measure the AFR at cruising speed. You made a big jump in power and you may be undercarbureted and running lean at cruise. It may not be off by much (since the temp climbs slowly), but running lean will make the engine run hot. It goes back to normal at idle since the mixture usually runs fairly rich (12-14 AFR) to get a smooth idle. Bruce |
An easy way to check high under chassis tem is to do what tech inspector said.
This will relieve under hood pressure Dont go messing around with clutch fans until u find whats wrong. A lean condition on a holley carb usually will make the motor stumble(flat spot in carb) at about 5 to 7 in. hg. If ur plugs look gud dont mess with jetting. I really believe u have high pressure under chassis!! |
You didn't say what kind of car this is. All stock cars have some kind of baffling to force air to go into the radiator and prevent under hood air from coming over the top of the rad or around the sides and going back thru it. Many cars have a spoiler under the rad to prevent air from going forward and under the rad. It also aids in providing a slightly lower pressure behind the rad causing the air to naturally flow thru it. If you have removed this it needs to be replaced or correctly modified to fit.
| Recent General Rodding Tech posts with photos |
| BBC Heads. Series vs Parallel Cooling. Check out these Pics | leejoy | Engine | 10 | 11-09-2007 03:49 PM |
| Wizard Cooling Aluminum Radiator | clinthart | Hotrodders' Lounge | 11 | 02-25-2006 08:04 AM |
| aluminum manifold, aluminum heads, bolt torque | william27103 | Engine | 8 | 11-07-2004 05:46 AM |
| need help quick, reverse cooling flow heads on old block...... | Gino Fultano | Engine | 1 | 09-10-2003 08:27 PM |
