cooling engine compartment - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-03-2009, 10:41 AM
Mark,
you didn't say,,,what is the header heat problem???
why do you think you need to reduce the headers heat?
motor running hot?
cooling the headers with fans won't help that much at all...
(and blowing hot air at the firewall will make the interior hotter)
because of the HUGE amount of pipes surface square inches radiating tremendous btu's of heat,,,they do make a engine compartment hotter versus a stock exhaust manifold....
1985 C-6 truck tranny, no engine braking effect fast68 Transmission - Rearend 40 02-04-2008 06:55 PM
painting the engine compartment on 71 camaro jd71cam Body - Exterior 1 01-12-2008 11:14 PM
cooling engine in traffic JUSTINH Engine 1 08-27-2003 09:31 AM
engine compartment panel replacement 67stang Body - Exterior 3 01-20-2003 06:01 AM
Engine Compartment Liner Mike Fryer Body - Exterior 1 10-21-2002 07:21 AM
