Cooling and exh problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2013, 05:19 PM
vht vht is online now
First off, on my 72 chevelle, put a set of Hooker super comps on and have crossmember problems. They are close to the floor and are headed right at the trans crossmember. The car was a SB, so would the BB one work better? The reducer actually hits on the left side, so there's not enough room to make a bend in 3 in exh. 2nd problem, GM universal rad isn't going to work. I guess I'll have to buy a alum direct fit for it. Now I have a gm and a ford style, universal, rads laying around not doing me any good. Was going with a elec fan, but may go with eng driven, after all this. that brings up another question, what fan have you all used? I know they used to have problems with the blades coming apart on some. Thanks for listening, what little bit I tried to do today didn't go so well.
Old 02-25-2013, 06:33 PM
vinniekq2's Avatar
take a picture of your exhaust? I have full 3 inch on my corvette??? chevelles have more room,hookers usually fit well.
I use a dimple core rad and it works great.The stock BB gm rad is pretty good,,,,
Old 02-26-2013, 05:56 PM
I found a Champion rad with 2 14 in fans and alum shroud for a good price. I'm going to try and notch the crossmember and box it in. The trouble is they are so close to the floor and I can only notch so much. They fit perfect everywhere else. I'll see what happens.
Old 02-27-2013, 10:53 AM
bigdog7373's Avatar
Of course it's fast
This is a good rad for your car JEGS Performance Products 51901 JEGS Direct Fit Aluminum Radiators
I run a stock pump driven fan and clutch on my car. Works awesome. You can get them at parts stores still. I got it at autozone.
What part number are your headers? On a full frame car like a chevelle they should be perfect otherwise I'd send em back. That's unacceptable.
Old 02-27-2013, 05:48 PM
I called Jeg's, they said that rad wouldn't cool mine, 650 HP, they said I needed the $500 and some dollar one. Champion has a larger rad, dual 14in fans with shroud for a little less than $400. I notched and boxed the crossmember tonight, seems like it's going to work alright. I've heard clearance problems with the Hookers everywhere else, steering shaft etc., but mine fit perfect except for the trans crossmember. I even have pretty good plug clearance with the angle plug heads. I cked on the Dart block, and it's suppose to be idenical to a stock block, I thought that might be the problem. Hopefully I won't run into anything else, and I can hear this thing run soon. Right now I gotta stop and put a set of injectors in a 6.0 ford deisel. Thanks for the help.
Old 02-27-2013, 06:09 PM
vinniekq2's Avatar
My car stays cool using an aluminum dimple core rad.I dont use a fan on the water pump at all.
what engine are you using? why are you worried about over heating? are the heads aluminum or iron?
Old 02-27-2013, 06:59 PM
Alum dart 230 heads, 434 sbc eng. Jeg's told me it'd over heat with their rad, only good for 450 hp. They wanted to sell me a $500 one. The 1 I'm getting is a 3 core, 28 1/2 in core that is a direct fit. Tanks are 3 in like the stock one I took out.
Old 02-27-2013, 07:16 PM
vinniekq2's Avatar
My 434 doesnt over heat with my rad? I dont use a fan on the water pump.Buy the good rad then?what camshaft are you using?
Old 02-27-2013, 07:26 PM
It's a Bullet, mech roller, 640 lift, 260 dur at 050. I'm not using a eng fan, 2 14in elec on a thermostat. That rad may cool it, but this 1 will do it with no problem and the price is right.
Old 02-27-2013, 07:39 PM
vinniekq2's Avatar
post a video when its running.gotta see the power
Old 02-27-2013, 09:38 PM
bigdog7373's Avatar
Of course it's fast
They're only trying to sell you the more expensive part cause it's their job. The one i posted is a big rad. An inch thick! My stock rad is maybe half an inch thick and still keeps my car cool in 95*+ heat. It's up to you, if you feel better with the other one then by all means go for it. It is your car after all.
Anyway, sounds like an awesome build. Post some pics, i'm a huge chevelle fan.
Oh and those 6.0 powerstrokes are a nightmare! Worst motor ford has ever put into a truck, well tied with the 6.4. Good luck with that project.
Old 02-28-2013, 05:44 PM
6.4 is a whlole lot worse to work on. Got in another 6.0 today. On the rad, I knew I probrably use the Jeg's, but by the time I bought the elec fans and shroud it'd been more money. Champion has a nice looking set up, with a 3 row rad, alum shroud, and 2 14in fans for $369. I ordered it today, he said it'd be a direct bolt in. This thing should run decent I hope. One day I'd like to build a blower motor with efi, but a little thing called money keeps getting in the way. Friend of mine has a S-10 with a 383 sbc, 6.71, and it went 10.87 spinning like crazy with a set of small heads. He's updating the fuel sys and he's done put on a set of nice Brodix heads. I'd like to see what it runs now. It's narrowed with a 4 link, he drives it all over, and the thing handles way better than I would of thought.
Old 02-28-2013, 08:14 PM
bigdog7373's Avatar
Of course it's fast
That's a smokin deal on that rad.
I still haven't figured out why ford ditched the 7.3 ps. It was their only good diesel. The new 6.7 looks cool though, wonder if its gonna have any problems like the 6.0 and 6.4...
No way I'd buy one though, I'm a d-max fan no matter what.
Old 03-01-2013, 10:56 AM
The 7.3 wouldn't meet emissions. The 6.7 is better but there's still some problems.
Supercharger cooling problems? Red72Nova Engine 4 05-09-2008 12:00 PM
cooling problems?? jivetrky Engine 1 02-12-2007 05:00 PM
Cooling problems nsayers88 Engine 12 12-20-2004 02:18 AM
cooling problems never end fast times General Rodding Tech 11 07-15-2004 05:00 AM
More SBC Cooling problems/questions hiimed Engine 14 07-11-2003 08:46 AM
