cooling fan - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2010, 11:34 AM
cooling fan
does the sending unit supply power or a ground to the fan
Old 10-15-2010, 11:48 AM
delawarebill's Avatar
fans
usually it supplies the ground side. but if u have a two prong sending unit it may be used to pass on 12+.
Old 10-15-2010, 12:37 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
The temp sensor in the block, is this what you are referring to as a sending unit?
http://www.speedwaymotors.com/AFCO-E...ree,39909.html
If so here is the way it works, first off the fan is normally wired with a relay, the relay uses battery voltage via the relay contacts to turn on the fan.
On the relay you have a coil with 2 pins, one is supplied by the same battery voltage .. The other pin will have a wire too the temp sensor, as the sensor comes up to temperature it goes to ground; the coil is energized;closes the contacts of the relay and the fan is turned on.
A quick check of the circuit can be done by simply removing the wire from the temp sensor and grounding it to the block, the fan will turn on. This tells you that the circuit is working. If the relay,or the fan or fuse if used, were to be bad the fan would stay off .
If the fan comes on grounding the wire and your fan does not come on when the car is at temperature, then the temp sensor has failed and needs replacement.
delawarebill is correct about the two pin type, so figure out the type you have, that will change the troubleshooting procedures.
Electric Cooling Fan Conversion 84Caprice57 Engine 4 07-05-2009 09:43 PM
N-body cooling fan ckucia Electrical 5 01-18-2008 09:11 AM
Electric cooling fan Z-Money Pit Engine 1 08-29-2006 08:27 PM
Electric Cooling Fan Mounting subman17 Engine 2 10-22-2004 12:15 PM
Cooling Fan for 6 volt system flatheadharold Electrical 2 09-01-2004 09:31 AM
