Magnum is correct. The best combination would be a puller electric fan mounted on the engine side of the radiator with a shroud. You could leave the engine driven fan on if you want but all you will be doing is using horsepower to drive it. It won't help in cooling the motor with the setup I've described.
Centerline
http://www.hotrodsandhemis.com
