cooling fan problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2003, 08:40 AM
1969 Camaro owner
cooling fan problem
Its a dodge aries that I recently put the engine back into. What is happening is that as soon as I connect the battery, the radiator fan starts up and when the engine is running the fan stops. I couldn't have anything plugged in wrong as all the connectors are different shapes or located when I could not possibly mess it up. I checked the fuse circuits and even unplugging the cooling fan fuse didn't stop it when the car is shut off. Not sure whats going on here. Any help would be appreciated.
Old 07-11-2003, 03:12 AM
New Member
I do not know if this applies and it is real strange but some years ago I worked on a ford with the same fault. It turned out that there had been or was a facility for an electric choke as well as fan, the choke and fan sensor plugs and sensor wher vertually identical in apperance and as you may be one step ahead the fan was connected to a choke swith not fan swith in the cooling line.
this gave exactly the same results you discribe.
Other than that dissconnect the fan swith / sensor fron the cooling and see if still runs ign on / off etc, if no a swith problem seems to exist.
If yes then relay / ign problem.
Have you disturbed any of the fan relay wiring as the relay coil ground or connections may be the issue here.
need more info
