Cooling Indication 454 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2010, 02:15 PM
Where can I find a detailed wire diagram of the for the cooling system on a 1988 k3500 454tbi. Replaced both temp indicator sensors above ex manifold. replaced temp sensor by thermistat. Replaced whole cooling system, Rad/Pump/Therm/Hoses. The eng temp is normal by feel. hot H20 on top hose, cool H20 on bottom hose. Indications run at 240 Plus, after shut down, gage will peg out. I suspect I have a bad wire. But the real problem is it runs rough at idle, as if it was telling the MAP sensor the eng is hot. I replaced the map sensor. When I pull off the temp sensor off the drivers side manifold it shows O on the gage, this wire seems to ground out, its not the sensor, tested that. Any input on this????????????
Old 12-03-2010, 09:44 PM
001mustang's Avatar
Not much help I know.
I like to use IR gun to get a pretty good cross reference indication of actual T-Stat operating temp, head temp, etc. Helps me verify if dash gauge is honest.
Old 12-03-2010, 10:01 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
This is a repeat of a post from 2 weeks ago.
Have any of the replies from that helped?
It would be more constructive if you could stay with the original post.
We all want to help and learn from the questions posted.
vicrod
Old 12-03-2010, 10:28 PM
001mustang's Avatar
That explains why no one answering this post.
Old 12-04-2010, 05:03 PM
I found i did not properly adjust the rocker arms. With the engine running, I loosened the rocker arms until they rattled than snug, than tightened 3/4 a turn. Engine runs great now and cools. The Infer Red therm tester worked great and gave me some great input. Thanks for all of your help.
replacing a 454 with a 350...... Treozen Engine 8 03-05-2008 01:28 PM
5.0 to 7.4 swap Tilar Engine 7 02-09-2008 06:51 PM
454 into 427 Alan Byers Engine 22 01-18-2008 12:36 PM
454 cooling probs Classix_Lover Engine 22 07-27-2005 01:49 PM
454 or 427 for 70 Chevelle? f100beatertruck Engine 3 11-25-2003 05:29 PM
