Cooling Indication 454 GMC - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2010, 02:16 PM
Where can I find a detailed wire diagram of the for the cooling system on a 1988 ck3500 454tbi. Replaced both temp indicator sensors above ex manifold. replaced temp sensor by thermistat. Replaced whole cooling system, Rad/Pump/Therm/Hoses. The eng temp is normal by feel. hot H20 on top hose, cool H20 on bottom hose. Indications run at 240 Plus, after shut down, gage will peg out. I suspect I have a bad wire. But the real problem is it runs rough at idle, as if it was telling the MAP sensor the eng is hot. I replaced the map sensor. When I pull off the temp sensor off the drivers side manifold it shows O on the gage, this wire seems to ground out, its not the sensor, tested that. Any input on this????????????
Old 11-18-2010, 11:30 PM
Last journal entry: day # 6 1929 ford wheel and body mach up .
run hot?
try checkin with thermomter have seen bad ignition swiches cause simler problems in those years everything from trans to tailamp problems /found problems in the colum it self in big blocks ecessive heat at exaust manifolds hard on wires /i always add exra quart of oil to prevent front rod and main damdge your probly beter off to go with manual gadge?
Old 11-19-2010, 05:06 AM
The stock temp sensor should be on the driver's side just above the exhaust manifold, and the other side should have the same sized hole with a plug in it.
I would add a mechanical temp gauge sender on the passenger side, which will give you a reading that does not depend on electrical grounding or power. When you compare the two gauge readings (electrical and mechanical), you should only have a few degrees difference. If not, then you need to troubleshoot the electric gauge until you get it to read accurately.
Bruce
Old 11-19-2010, 02:31 PM
I found one temp sensor on the pass side reads 75 degrees from the drivers side so I'm going to replace it tomorrow. I' update than, thanks alot for the info.
Old 11-19-2010, 02:36 PM
Other than one temp sensor reading higher than the other, I found oil pressure wires were stripped at the cannon which could of been arching next to each other. So I hope tomorrow after I put in the temp sensor, I maybe can push it out of the shop. THanks
454 build - up ... opinions? 66GMC Engine 14 04-25-2011 08:46 PM
454 Getting hot Torque454 Engine 4 03-21-2010 01:14 PM
need help with my 454 build black_chevy Engine 9 12-09-2009 04:22 PM
454 in 72 gmc pickup djackson88 Engine 3 05-01-2009 01:10 PM
454 2bolt 289 block or 4bolt 454 1 piece seal to build a 496 heathj1 Engine 2 12-21-2008 10:22 AM
