How hot is it getting? Does it have a serpentine or V belt set up? In many cases a V belt is used in S10`s for more clearence and the water pump is left, the serpentine water pump is reverse flow and will run hot on a standard flow V belt set up.
http://store.summitracing.com/partde...5&autoview=sku http://store.summitracing.com/egnsea...0+115&y=4&x=39 http://www.parts123.com/parts123/yb....Z5Z5Z50000050F If you want brass and copper early 70's Malibu's, Camaro, etc can be adapted. http://www.radiator.com/chevrolet-ma...20L-8&cmp=base Pick the thickest core 3 or 4 tube type from air conditioned models with an automatic. I'm not recommending you buy from any of these places, just giving you ideas. The Malibu radiator will not fit with conventional top mounts. Locate it on the bottom as stock, You may have to drill additional holes in truck's radiator frame or frame rails to mount them. The top uses the stock rubber insulators but rotated to the front of the radiator, trim as necessary for hood clearance. Drill thru the truck's radiator frame and the radiator's frame close to the mounts and secure with a long enough 1/4 inch machine screw and self locking nuts. The 4.3 V6 radiator will not cool a 350 period, don't even screw around with the thought, it's a complete waste of time. Dual fans ahead of the radiator is about as good as it gets. A factory fan can be run behind but there isn't much space for a shroud so you will always find this touchy in stop and go traffic and idling around. But any of these will keep it cool buzzin' down the interstate. My recommendation if you go into a factory fan is to drop back to a short pump and get the pulleys and accessory brackets necessary to back date their locations on the engine. Don't bother with simple round fan shrouds they don't accomplish pulling a low pressure area behind the entire core and, therefore, are in-effective. Make sure any electric fans mount to the truck's radiator frame, never to the radiator, they will shake it apart. Ditch the stupid serpentine system, all the giant brackets do is just add weight, take up space, and interfere with trying to get cooling air thru the radiator and around the engine. Keep in mind that serpentine water pumps and fans turn opposite to V belts so you have to drop back to pre-serpentine parts for the swap. I like to use the aluminum Edlebrock pump as it knocks a few more pounds off the front wheels. When your ready we can talk about suspension mods that will make it handle like a Beemer and not kill you with ugly surprises. You'll lose the engine oil heater inside the radiator with some of these, no biggy just takes a couple more miles to get it up to operating temp. But you if you loose the oil heater you'll need to re-plumb the tubes to and from it or better yet, remove the adapter above the oil filter, doing away with the whole system. Bogie Last edited by oldbogie; 05-15-2009 at 05:54 PM. Reason: better sentence structures |
195 thermostat will allow the engine to run at factory correct operating temps
i would dump the 160 warmer temps actually is better because it does things such as allow the air fuel mixture to combust properly/completely among other things sounds liek you have a cooling issue due to radiator size/condition, hose restriction, bad or missing or worn water pump, missing or broken fan shroud, crappy flex style fan or faulty fan clutch are both hoses hot when running hot ? if not then you have a plugged rad or bad water pump can you see good flow inside under the radiator tank cap when running ? use a flashlight just trying to help good luck Last edited by fast68; 05-15-2009 at 10:05 PM. |
cooler stat temps won't cure overheating, only delay it. Overheating is caused by more heat going into the coolant than can be shed by the cooling system. The temperature at which the stat opens has nothing to do with that.
Improve the way it gets rid of heat; better radiator is the first thing I'd do. Most swappers go cheap on the radiator because installing a bigger radiator means modifications they don't want to do. Then they skimp on electric fans and they don't work well. A well-designed, heavily researched electric fan setup will properly cool big HP, but so many times people buy the cheapest, largest, thinnest fan that will fit and wonder why their $119 fans won't do the trick. The only time I ever bought an electric fan was for a Caddy 500 making about 450 hp. It was the best fan on the market at the time, proven over and over. It cost $650 and drew almost 30 amps, so one can't expect a "jeg's super cool" twin 10-inch fan to effectively cool anything but a 4-cylinder Honda. Look to the Spal brand for absolute top-quality electric fans. Vintage Air also sells Spal fans under their "monster cooler" name. |
Bogie |
Bogie |
| 350 chevy small block over heating? | xxxtonyrusxxx@yahoo. | Engine | 37 | 09-27-2011 06:10 PM |
| 396 Cooling issue | onefastchevy | Engine | 43 | 07-20-2008 01:45 PM |
| cooling issue | ffcagle34 | Engine | 15 | 09-05-2007 03:05 PM |
| Cooling issue | Nemisis | Engine | 7 | 02-14-2006 01:00 PM |
| Cooling System Flush | 73oldsman | Engine | 2 | 02-13-2006 07:31 PM |
