cooling issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2006, 01:21 AM
94impalass's Avatar
cooling issues
okay i am trying to cool a 427 BB with an automatic trans, i was wondering if i could get a universal aluminum radiator and then get a separte transmission cooler if it would work.
Old 09-24-2006, 09:02 AM
75gmck25's Avatar
There's no reason it wouldn't work, and there are also at least a couple of companies who also sell universal aluminum radiators with a built-in trans cooler. Check the Jegs or Summit catalogs to take a look at them.
Brcuce
Old 09-24-2006, 03:16 PM
94impalass's Avatar
okay so should i measure my factory radiator and try to find the closest one to would match the factory or should i just go with a direct fit one?
Old 09-24-2006, 03:45 PM
75gmck25's Avatar
I'd go with direct fit if you are willing to spend the money. A direct fit Be Cool radiator for a '94 Impala with auto trans is about $700 from Jegs. The universal fit is only about $250, but you'll spend more time getting it to installed and adapting it to your car.
Bruce
Lowering - Camber issues 49lincoln Suspension - Brakes - Steering 1 05-25-2006 12:24 AM
Single pass Radiator VS Cooling issues... Ratoflic Engine 7 05-22-2006 04:07 PM
Cooling System Flush 73oldsman Engine 2 02-13-2006 07:31 PM
Enough Cooling? jamnut Engine 3 07-18-2003 01:13 AM
Cooling Issues rehjr0219 Engine 6 03-21-2003 03:39 PM
