Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cooling Issues. Even With No Thermostat
Old 10-25-2011, 07:56 PM
gmc1990rodder's Avatar
gmc1990rodder gmc1990rodder is offline
surely need the t-stat try 195 degree second did u reverse flush the cooling system? its simple to do even if the engine isnt running...assuming u have a heater disconnect one hose,attach a water hose and a lil duck tape to hold in place lol turn on the water w/radiator cap off water should folw out off the top...if not try the water hose on the opposite heater hose... also did u dran the block by the to plugs on the bottom?? after u pull the plugs out and have no water flowing ouy of them..insert a small screwdriver thru the rust until it flows.... after u turn the water on allow to run thru system until it runs clear
