Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cooling Issues. Even With No Thermostat
Old 10-25-2011, 08:36 PM
killerformula's Avatar
killerformula killerformula is offline
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
It sounds like you maybe had a thermostat in this car and then took it out to see if you could improve cooling? First thing's first, you do have to run a thermostat. Second, I would check the pressure in your system to be sure you've got proper pressure. Low pressure will cause you to overheat as well.
K
