Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cooling Issues. Even With No Thermostat
Old 10-27-2011, 08:53 AM
ap72 ap72 is offline
Banned
The thermostat does NOT let the coolant cool down easier, whomever thinks that needs to pull their head out of their ***. On a street car a thermostat is necessary though to maintain enough heat in the engine, running too cool is just as bad as running too hot. As mentioned, system pressure reduces localized boiling, which is important, and airflow across the radiator is needed to remove the heat from the cooling system.
