Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cooling Issues. Even With No Thermostat
  #21 (permalink)
Old 10-27-2011, 04:57 PM
stroker_SS stroker_SS is offline
Everything is HAMMER!
Hey Oldbogie....
Dex-Cool wasn't used in GM vehicles until 1996, so it is safe to assume that any standard 350 would be better off with original green like the chart shows(lower), and all of the "universal, mix with any color, all makes all models" coolants are generally of the same chemical make up as Dex-Cool using an organic acid called "2-EHA". Take a look at the PDS for any of the universals and compare it to Dex-Cools. This isn't a personal attack and as long as I have been here you have usually been a great source of info, take it easy OB.
