cooling a peformance engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2011, 12:40 PM
i have a 2 core 31X19 all aluminum radiator and i want to cool a pontiac 400 stroked to a 468 10.5:1 cr edelbrock aluminum heads 750 series carb also edelbrock aluminum roller rockers undecided on cam yet have no clue were to even start their torker 2 intake everything is ported and polished... anyway i wanna cool it with my 31X19 aluminum radiator that should be enough right i dont know how it could get any better but i thought id ask because i v had people say this engine would be harder to cool then the factory...
Old 01-31-2011, 01:49 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Should be fine but only one way to know for sure, What type fan and shroud are you going to be running with this radiator ? What brand radiator is it anyway ?
Cole
Old 01-31-2011, 02:12 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Are you using an OEM 400 block, 4.124 x 3.75? What's the bore/stroke for this 468, something like 4.185 x 4.25?
I'm sure it's been done, but seems pretty aggressive, even for a Pontiac block. I"m curious what the clearance issues or problems are with that stroke, over and above a measly 383 Chevy.
Old 01-31-2011, 02:42 PM
Cole
be cool brand with a dual electrics attached
Old 01-31-2011, 02:46 PM
its actually a 467 7 and 8 are to close on the keyboard 4.250 inch crank 4.181 bore 6.800 rods
came as a kit i got it from butler performance also thought id add it seems agressive if you think about it 400 to a 467 but you have to remember Pontiac used the same block on almost all their v8's only difference between the 400 and a 455 is bore and stroke
Old 01-31-2011, 06:25 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
i'm not a pontiac guy so i've never played with the 400, i have no doubt that pontiac used the same blocks for their 400 as the 455 but you have to think about the alighnment of the bores, from centerline of the cylinder to centerline of the next cylinder is not likely the same in a 400 as it is in a 455. chevy did the same thing from 396-454, but you're not going to find someone punching a 396 out from 4.094 to 4.250 as well as stroking it up to a 4.00 crank.
i just looked up the bore and stroke of both the pontiac 400 and 455, and see that bore wise there isn't a great deal of difference so i would say that is very possible but stroke wise the are almost .5" apart. and you say that you are using a 4.250" crank so that is a full .5" increase in stroke. now like i said i dont know much about pontiacs but that does seen like a whole lot to increase the stroke on a OEM block, it will require some serious clearancing (i would think)
Old 01-31-2011, 06:33 PM
I too am searching for a radiator for a much tamer Pontiac 400. The only thing I would check is the radiator tube diameter. Hopefully it's 1".
BT
Old 02-01-2011, 06:37 AM
65 Imp SS's Avatar
Stewart Components has a guide to high performace cooling on there site in tech tips here:
http://www.stewartcomponents.com/Tech_Tips.htm
Old 02-01-2011, 06:53 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The Pontiac block will swallow a 4.25"/4.5" stroke crank w/o much clearancing at all- mainly up at the front of the block.
From BUTLER:
Old 02-01-2011, 02:16 PM
my87Z's Avatar
wow, i didn't know that
Old 02-01-2011, 04:01 PM
what i did to cool it
hey rt, jessebelle here. i have a 65 dodge coronet 440. it has a supercharged 440, .030 over, 6-71 gmc blower, 2-650 double pump holly's,makes 9psi-boost-600+h.p. exhaust manifolds are cast iron, replicated from the 60's. exhaust is 3" tti. 727 automatic, 3:93 posi rear end. all detailed, as is yours. i read in hot rod mag, drain/flush cooling system throughly. use a 180 degree thermostat. an aluminum radiator is mandatory, and fabricate an aluminum shroud to direct all air into the radiator, not around it. i used an electric fan, as high a cfm as i could get, takes less hp away from the motor, i put it on an off/on switch, no fan thermostat, they are costly, not needed. pipe in a direct reading water temp gauge. re-apply the block plugs, close rad. petcock. refill the rad. with cold water, fire up, and when thermostat opens, top off rad. with water only, leaving room for expansion, and room for a container of WATER WETTER coling system additive(auto zone-$10.00). use a 16 psi or higher rad. cap. no anti freeze, water cools better. this really worked for me, incredable stuff. i drive the car on the street @190 degrees in summer. good luck, advise me on the results. jessebelle
305 Peformance EastCoastSBC Engine 4 08-18-2006 02:44 PM
Engine Cooling Malibu1980 Engine 2 03-28-2004 08:13 AM
Engine cooling help t-bird Engine 1 01-24-2004 01:27 PM
Engine cooling 54 Hottie Engine 2 05-02-2002 05:00 PM
