Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cooling problem
Thread: Cooling problem
Old 03-28-2013, 04:34 PM
46streetrod 46streetrod is offline
A little more info needed. What fan are you running ? There are fans and there are fans.Cheap fans are not good fans. Also are you running a Tri=nary switch on the AC to control the fan. Are you running the stock Radiator? If so I would be leary of running a higher psi cap, If its a newer radiator go to a 16 lbs cap .For every 1 lb = 3 degrees over boiling point.Also what is the air gap between the condenser and the radiator?
