-   -   Cooling Question (http://www.hotrodders.com/forum/cooling-question-134123.html)
mightycarlo10 02-26-2008 12:11 PM
Cooling Question
I pulled the ac/heater blower unit box thingamajig out of my 87 Monte Carlo and put in a 383 and TH350. My question is can i just connect the two coolant lines that go to the heater core. I have heard people just blocking the ports, but i thought that the heater core and lines were important because when the thermostat is closed, thats where the coolant flows and circulates.
Jmark 02-26-2008 01:24 PM
You can loop them together or block them off, won't make any difference in flow.
BogiesAnnex1 02-26-2008 01:35 PM
You'll have to cut and try, some SBCs are really sensitive to the heater circuit as a bypass, others are not. In theory, there is a bypass hole below the the right side water pump mounting horn. This is supposed to provide a bypass when the thermostat is closed. It often is insufficient to keep the pump from cavitatng and hot spots from local boiling. The pass through the heater or a simple bypass loop without the heater insures this won't happen.
Bogie
